Hi team,
I've started to experience Fatal trap 12 after upgrading to 11.3 then upgrading zfs pool on one of my disks (WD NAS 3.0 TB).
I'm able to start the system but, if I leave the drive in I still get into fatal trap 12. If I insert the drive after system has successfully booted, I can see the disk and after attempting to import the volume (I guess it still recognize there is one) I get the following error:
Request Method: POST
Request URL: http://192.168.2.117/storage/auto-import/
Software Version: FreeNAS-11.1-RELEASE (dc7d195f4)
Exception Type: MiddlewareError
Exception Value:
[MiddlewareError: The volume "zfsVol1" failed to import, for futher details check pool status]
Exception Location: ./freenasUI/middleware/notifier.py in volume_import, line 2647
Server time: Sun, 5 May 2019 14:40:54 -0700
Traceback
Environment:
Traceback:
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner
42. response = get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response
249. response = self._get_response(request)
File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response
178. response = middleware_method(request, callback, callback_args, callback_kwargs)
File "./freenasUI/freeadmin/middleware.py" in process_view
162. return login_required(view_func)(request, *view_args, **view_kwargs)
File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view
23. return view_func(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in view
68. return self.dispatch(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in dispatch
237. response = super(WizardView, self).dispatch(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in dispatch
88. return handler(request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in post
300. return self.render_done(form, **kwargs)
File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in render_done
357. **kwargs)
File "./freenasUI/storage/forms.py" in done
881. self.volume = notifier().volume_import(vol['label'], vol['id'], key, passphrase, enc_disks)
File "./freenasUI/middleware/notifier.py" in volume_import
2647. 'for futher details check pool status') % volume_name)
Exception Type: MiddlewareError at /storage/auto-import/
Exception Value: [MiddlewareError: The volume "zfsVol1" failed to import, for futher details check pool status]
Request information
GET
No GET data
POST
Variable Value
auto_import_wizard-current_step '2'
2-__all__ ''
2-volume_id 'zfsVol1|10984135251537352646'
__form_id 'dijit_form_Form_2'
FILES
No FILES data
COOKIES
Variable Value
csrftoken '3B3CiPTmRLZeksaG6bI6Jr8lqSKuyFbHhxWimQgLCC3XCs01Dj3LqbZHPh21nd5j'
sessionid 'r9y2sejbcqj8i01s4iupk9gjnexq7pp4'
fntreeSaveStateCookie 'root%2Croot%2F59%2Croot%2F59%2F60%2Croot%2F98%2F102%2Croot%2F98%2F111%2Croot%2F98%2F111%2F113%2Croot%2F98%2F111%2F122%2Croot%2F60%2Croot%2F60%2F61%2Croot%2F60%2F61%2F66%2Croot%2F60%2F78'
META
Variable Value
Here are system info:
Platform Intel(R) Core(TM) i7 CPU 950 @ 3.07GHzMemory 8145MBSystem Time Mon, 6 May 2019 15:17:13 -0700Uptime 3:17PM up 6:10, 0 usersLoad Average 0.09, 0.16, 0.18
Exception Value:
Traceback
Environment:
Traceback:
357. **kwargs)
Request information
GET
No GET data
POST
Variable Value
2-__all__ ''
FILES
No FILES data
COOKIES
Variable Value
META
Variable Value
