Hi everyone!
I've been experiencing some errors when importing an encrypted volume on FreeNAS 9.10.2 U2, U3, U5 and now 11.0-RELEASE.
Second level dirs and below does not mount. I believe that this error stems from it being a read-only volume (used as an off-site replication target).
So I wonder, is this by "design" or is it something that can be fixed? Replication does seemingly still work. Maybe I'm going out on a limb here but could it be possible to fix this by changing the read-only attribute?
OT: Has it always been the default to automatically send crash reports?
It shall be noted that this volume (the disks) was moved off-site (post replication) to another FreeNAS system. The original system was shut down before the removal of the disks but no other actions were performed.
Request Method: POST Request URL: https://192.168.7.10/storage/auto-import/ Software Version: FreeNAS-11.0-RELEASE (a2dc21583) Exception Type: MiddlewareError Exception Value: [MiddlewareError: b'The volume "slowraidz2" failed to import, for futher details check pool status'] Exception Location: ./freenasUI/middleware/notifier.py in volume_import, line 3116 Server time: Fri, 16 Jun 2017 16:06:11 +0000 Traceback Environment: Software Version: FreeNAS-11.0-RELEASE (a2dc21583) Request Method: POST Request URL: https://192.168.7.10/storage/auto-import/
Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in view 68. return self.dispatch(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in dispatch 237. response = super(WizardView, self).dispatch(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/django/views/generic/base.py" in dispatch 88. return handler(request, *args, **kwargs) File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in post 300. return self.render_done(form, **kwargs) File "/usr/local/lib/python3.6/site-packages/formtools/wizard/views.py" in render_done 357. **kwargs) File "./freenasUI/storage/forms.py" in done 877. self.volume = notifier().volume_import(vol['label'], vol['id'], key, passphrase, enc_disks) File "./freenasUI/middleware/notifier.py" in volume_import 3116. 'for futher details check pool status') % volume_name) Exception Type: MiddlewareError at /storage/auto-import/ Exception Value: [MiddlewareError: b'The volume "slowraidz2" failed to import, for futher details check pool status']
Request information GET No GET data POST Variable Value auto_import_wizard-current_step '2' 2-__all__ '' 2-volume_id 'slowraidz2|7473525507379358860' __form_id 'dijit_form_Form_2' FILES No FILES data COOKIES Variable Value csrftoken 'xyz' fntreeSaveStateCookie 'root%2Croot%2F1%2F5' sessionid 'xyz' META Variable Value
Jun 16 16:06:11 freenas2 uwsgi: [middleware.notifier:2975] Importing slowraidz2 [7473525507379358860] failed with: cannot mount '/mnt/slowraidz2/backup/dc': fai led to create mountpoint cannot mount '/mnt/slowraidz2/backup/old': failed to create mountpoint cannot mount '/mnt/slowraidz2/backup/old/dc': failed to create mountpoint cannot mount '/mnt/slowraidz2/backup/time': failed to create mountpoint cannot mount '/mnt/slowraidz2/users/user0': failed to create mountpoint cannot mount '/mnt/slowraidz2/use Jun 16 16:06:11 freenas2 uwsgi: rs/user1': failed to create mountpoint cannot mount '/mnt/slowraidz2/users/user2': failed to create mountpoint
Jun 16 16:06:11 freenas2 uwsgi: [raven.base.Client:214] Configuring Raven for host: <raven.conf.remote.RemoteConfig object at 0x81ad07588> Jun 16 16:06:11 freenas2 uwsgi: [middlewared.logger.CrashReporting:84] Sending a crash report... Jun 16 16:06:11 freenas2 uwsgi: [raven.base.Client:635] Sending message of length 5781 to https://sentry.ixsystems.com/api/2/store/
