TrueTux
- Mar 11, 2024
Hey guys
I switched finally from CORE to SCALE (fresh install, no update). To be able to mount NFS shares inside VMs I followed the official documentation (Accessing NAS From a VM) and created a bridge interface. But after attaching the VM's NIC to the bridge, I get a strange error:
The VM is starting if I manually modprobe the tun module. But of course the tun device should not be needed here. Any ideas what I made wrong?
- TrueNAS-SCALE-23.10.2
- Asrock C2750D4I with 32GB ECC
- IPv6 disabled (net.ipv6.conf.all.disable_ipv6=1)
Thanks a lot for help!
Jakob
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 182, in start if self.domain.create() < 0: ^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/libvirt.py", line 1373, in create raise libvirtError('virDomainCreate() failed') libvirt.libvirtError: Unable to open /dev/net/tun, is tun module loaded?: No such file or directory During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/main.py", line 201, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call return await methodobj(*prepared_call.args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf return await func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf res = await f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 54, in start await self.middleware.run_in_thread(self._start, vm['name']) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1254, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 68, in _start self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name)) File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 191, in start raise CallError('\n'.join(errors)) middlewared.service_exception.CallError: [EFAULT] Unable to open /dev/net/tun, is tun module loaded?: No such file or directory
Jakob
