I try to add a bridge so that I can access my TrueNas services/apps from my VM.
I'm following the official instructions: https://www.truenas.com/docs/scale/scaletutorials/virtualization/accessingnasfromvm/
But when I get to the point where I test the changes, it spins for a while (60 secs, also tried with 180s) and reverts back all the changes. And I can't pinpoint what's wrong, there are not feedback. Are there any logs showing the test progress and failures? During the test I monitor the ping to the Truenas box and the IP doesn't respond until the revert happens.
I'm using an alias on the bridge to set the static IP. Should I use DHCP instead like I do for the physical NIC (before trying to setup the bridge)? I have a static lease setup but I'm not sure the bridge will expose the same MAC address.
I'm using TrueNAS-SCALE-23.10.1 with only one NIC. The NIC is currently set to get the IP over DHCP, and I configured a static lease.
I have running apps (I didn't see anywhere advise to shut them down) and two VMs (the one that needs the bridge is currently shutdown, again, should I turn off the other one?).
To get the logs I changed the test timeout to 30secs
log messages
Syslog
log messages
Dec 27 23:27:44 truenas kernel: br0: port 1(eno1) entered blocking state Dec 27 23:27:44 truenas kernel: br0: port 1(eno1) entered disabled state Dec 27 23:28:14 truenas kernel: e1000e 0000:00:1f.6 eno1: NIC Link is Down Dec 27 23:28:18 truenas kernel: e1000e 0000:00:1f.6 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx Dec 27 23:28:18 truenas kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes
Syslog
Dec 27 23:27:44 truenas avahi-daemon[3759]: Withdrawing address record for 192.168.120.3 on eno1. Dec 27 23:27:44 truenas avahi-daemon[3759]: Leaving mDNS multicast group on interface eno1.IPv4 with address 192.168.120.3. Dec 27 23:27:44 truenas avahi-daemon[3759]: Interface eno1.IPv4 no longer relevant for mDNS. Dec 27 23:27:44 truenas avahi-daemon[3759]: Withdrawing address record for 2a01:e0a:3a6:1200:f639:9ff:fe07:dd29 on eno1. Dec 27 23:27:44 truenas avahi-daemon[3759]: Leaving mDNS multicast group on interface eno1.IPv6 with address 2a01:e0a:3a6:1200:f639:9ff:fe07:dd29. Dec 27 23:27:44 truenas avahi-daemon[3759]: Joining mDNS multicast group on interface eno1.IPv6 with address fe80::f639:9ff:fe07:dd29. Dec 27 23:27:44 truenas avahi-daemon[3759]: Registering new address record for fe80::f639:9ff:fe07:dd29 on eno1.*. Dec 27 23:27:44 truenas avahi-daemon[3759]: Withdrawing address record for fe80::f639:9ff:fe07:dd29 on eno1. Dec 27 23:27:44 truenas avahi-daemon[3759]: Leaving mDNS multicast group on interface eno1.IPv6 with address fe80::f639:9ff:fe07:dd29. Dec 27 23:27:44 truenas avahi-daemon[3759]: Interface eno1.IPv6 no longer relevant for mDNS. Dec 27 23:27:44 truenas kernel: br0: port 1(eno1) entered blocking state Dec 27 23:27:44 truenas kernel: br0: port 1(eno1) entered disabled state Dec 27 23:27:44 truenas nscd[2724]: 2724 monitored file `/etc/resolv.conf` was written to Dec 27 23:28:14 truenas kernel: e1000e 0000:00:1f.6 eno1: NIC Link is Down Dec 27 23:28:15 truenas dhclient[73844]: DHCPREQUEST for 192.168.120.3 on eno1 to 255.255.255.255 port 67 Dec 27 23:28:15 truenas nscd[2724]: 2724 monitored file `/etc/resolv.conf` was written to Dec 27 23:28:18 truenas kernel: e1000e 0000:00:1f.6 eno1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx Dec 27 23:28:18 truenas kernel: IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready Dec 27 23:28:20 truenas avahi-daemon[3759]: Joining mDNS multicast group on interface eno1.IPv6 with address fe80::f639:9ff:fe07:dd29. Dec 27 23:28:20 truenas avahi-daemon[3759]: New relevant interface eno1.IPv6 for mDNS. Dec 27 23:28:20 truenas avahi-daemon[3759]: Registering new address record for fe80::f639:9ff:fe07:dd29 on eno1.*. Dec 27 23:28:20 truenas dhclient[73844]: DHCPREQUEST for 192.168.120.3 on eno1 to 255.255.255.255 port 67 Dec 27 23:28:20 truenas dhclient[73844]: DHCPACK of 192.168.120.3 from 192.168.120.1 Dec 27 23:28:20 truenas avahi-daemon[3759]: Joining mDNS multicast group on interface eno1.IPv4 with address 192.168.120.3. Dec 27 23:28:20 truenas avahi-daemon[3759]: New relevant interface eno1.IPv4 for mDNS. Dec 27 23:28:20 truenas avahi-daemon[3759]: Registering new address record for 192.168.120.3 on eno1.IPv4. Dec 27 23:28:20 truenas dhclient[73844]: bound to 192.168.120.3 -- renewal in 18913 seconds. Dec 27 23:28:21 truenas avahi-daemon[3759]: Leaving mDNS multicast group on interface eno1.IPv6 with address fe80::f639:9ff:fe07:dd29. Dec 27 23:28:21 truenas avahi-daemon[3759]: Joining mDNS multicast group on interface eno1.IPv6 with address 2a01:e0a:3a6:1200:f639:9ff:fe07:dd29. Dec 27 23:28:21 truenas avahi-daemon[3759]: Registering new address record for 2a01:e0a:3a6:1200:f639:9ff:fe07:dd29 on eno1.*. Dec 27 23:28:21 truenas avahi-daemon[3759]: Withdrawing address record for fe80::f639:9ff:fe07:dd29 on eno1.
