ATA error count
giuseppe30
I have TrueNAS-12.0-U3.1 machine with 3x HGST 8TB stripe pool and Dell perc h310.
today I have this critical message: ATA error count.
Model Family:     HGST Ultrastar HC310/320
Device Model:     HGST HUS728T8TALE6L4
Serial Number:    VGJT1PUK
LU WWN Device Id: 5 000cca 0bee71e4f
Firmware Version: V8GNW980
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Jun 14 21:51:29 2021 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x80) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (   87) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 873) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   132   132   054    Pre-fail  Offline      -       96
  3 Spin_Up_Time            0x0007   162   162   024    Pre-fail  Always       -       509 (Average 497)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       25
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   128   128   020    Pre-fail  Offline      -       18
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1059
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       25
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       67
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       67
194 Temperature_Celsius     0x0002   139   139   000    Old_age   Always       -       43 (Min/Max 23/57)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       13
SMART Error Log Version: 1
ATA Error Count: 13 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Error 13 occurred at disk power-on lifetime: 1056 hours (44 days + 0 hours)
  ER ST SC SN CL CH DH
  84 41 00 00 00 00 00  Error: ICRC, ABRT at LBA = 0x00000000 = 0
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 10 00 c8 cb a9 40 00      01:56:15.190  READ FPDMA QUEUED
  60 10 00 88 c8 a9 40 00      01:56:15.146  READ FPDMA QUEUED
  60 10 10 98 c8 a9 40 00      01:56:15.146  READ FPDMA QUEUED
  60 10 08 78 c8 a9 40 00      01:56:15.146  READ FPDMA QUEUED
  60 10 00 68 c8 a9 40 00      01:56:15.146  READ FPDMA QUEUED
Error 12 occurred at disk power-on lifetime: 1056 hours (44 days + 0 hours)
  60 10 00 e0 01 92 40 00      01:52:00.145  READ FPDMA QUEUED
  60 10 10 00 02 92 40 00      01:52:00.145  READ FPDMA QUEUED
  60 10 08 f0 01 92 40 00      01:52:00.145  READ FPDMA QUEUED
  60 10 00 d0 01 92 40 00      01:52:00.145  READ FPDMA QUEUED
  60 10 00 c0 01 92 40 00      01:52:00.144  READ FPDMA QUEUED
Error 11 occurred at disk power-on lifetime: 1056 hours (44 days + 0 hours)
  60 00 00 90 a2 9c 40 00      01:50:34.826  READ FPDMA QUEUED
  60 10 08 70 81 1c 40 00      01:50:34.826  READ FPDMA QUEUED
  60 10 10 80 a2 9c 40 00      01:50:34.826  READ FPDMA QUEUED
  60 10 08 70 a2 9c 40 00      01:50:34.826  READ FPDMA QUEUED
  60 20 00 50 a2 9c 40 00      01:50:34.826  READ FPDMA QUEUED
Error 10 occurred at disk power-on lifetime: 1056 hours (44 days + 0 hours)
  60 10 10 60 9f 70 40 00      01:46:33.674  READ FPDMA QUEUED
  60 10 00 80 9f 70 40 00      01:46:33.674  READ FPDMA QUEUED
  60 10 08 50 9f 70 40 00      01:46:33.674  READ FPDMA QUEUED
  60 10 00 70 9f 70 40 00      01:46:33.674  READ FPDMA QUEUED
  60 10 08 40 9f 70 40 00      01:46:33.670  READ FPDMA QUEUED
Error 9 occurred at disk power-on lifetime: 1056 hours (44 days + 0 hours)
  60 10 00 b0 d4 0b 40 00      01:39:12.529  READ FPDMA QUEUED
  60 10 08 c0 d4 0b 40 00      01:39:12.529  READ FPDMA QUEUED
  60 10 08 a0 d4 0b 40 00      01:39:12.529  READ FPDMA QUEUED
  60 10 00 90 d4 0b 40 00      01:39:12.529  READ FPDMA QUEUED
  60 10 10 70 d4 0b 40 00      01:39:12.529  READ FPDMA QUEUED
# 1  Short offline       Completed without error       00%      1059         -
# 2  Short offline       Completed without error       00%       989         -
# 3  Short offline       Completed without error       00%       821         -
# 4  Short offline       Completed without error       00%       581         -
# 5  Short offline       Completed without error       00%       416         -
# 6  Extended offline    Completed without error       00%       358         -
# 7  Short offline       Completed without error       00%       248         -
Etorix
No SMART error, no reallocated sector. This doesn't look too worrying for the drive, but I'd check the cable.
giuseppe30
I will try to replace it anyway.
What do you think about SMART messages "Error x occurred at disk power-on lifetime" and "Error: ICRC, ABRT at LBA = 0x00000000 = 0"
I read that as:
A cyclical redundancy check failure caused us to abort a command because we couldn't even contact the disk at all (hence no LBA).
giuseppe30
today I've cange sata connector P1 with P4 (not the entiere mini sas cable to x4 sata)
Local Time is:    Tue Jun 15 11:50:29 2021 CEST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       27
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1072
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       27
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       70
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       70
194 Temperature_Celsius     0x0002   153   153   000    Old_age   Always       -       39 (Min/Max 23/57)
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       21
ATA Error Count: 21 (device log contains only the most recent five errors)
Error 21 occurred at disk power-on lifetime: 1066 hours (44 days + 10 hours)
  60 10 00 b8 0c db 40 00      12:09:58.902  READ FPDMA QUEUED
  60 10 08 c8 0c db 40 00      12:09:58.901  READ FPDMA QUEUED
  60 80 00 38 0c db 40 00      12:09:58.901  READ FPDMA QUEUED
  60 10 08 58 0c db 40 00      12:09:58.901  READ FPDMA QUEUED
  60 10 00 48 0c db 40 00      12:09:58.901  READ FPDMA QUEUED
Error 20 occurred at disk power-on lifetime: 1064 hours (44 days + 8 hours)
  60 00 00 f8 88 da 40 00      10:09:52.889  READ FPDMA QUEUED
  60 20 70 e8 96 da 40 00      10:09:52.888  READ FPDMA QUEUED
  60 00 68 e8 95 da 40 00      10:09:52.888  READ FPDMA QUEUED
  60 00 60 e8 94 da 40 00      10:09:52.888  READ FPDMA QUEUED
  60 00 40 e8 93 da 40 00      10:09:52.888  READ FPDMA QUEUED
Error 19 occurred at disk power-on lifetime: 1064 hours (44 days + 8 hours)
  60 00 48 e8 42 da 40 00      10:09:52.829  READ FPDMA QUEUED
  60 00 70 e8 47 da 40 00      10:09:52.823  READ FPDMA QUEUED
  60 00 68 e8 46 da 40 00      10:09:52.823  READ FPDMA QUEUED
  60 00 60 e8 45 da 40 00      10:09:52.823  READ FPDMA QUEUED
  60 00 58 e8 44 da 40 00      10:09:52.823  READ FPDMA QUEUED
Error 18 occurred at disk power-on lifetime: 1063 hours (44 days + 7 hours)
  60 00 00 38 8b e0 40 00      09:09:35.822  READ FPDMA QUEUED
  60 f0 10 38 8d e0 40 00      09:09:35.821  READ FPDMA QUEUED
  60 00 08 38 8c e0 40 00      09:09:35.821  READ FPDMA QUEUED
  60 10 10 28 8b e0 40 00      09:09:35.821  READ FPDMA QUEUED
  60 10 08 18 8b e0 40 00      09:09:35.821  READ FPDMA QUEUED
Error 17 occurred at disk power-on lifetime: 1063 hours (44 days + 7 hours)
  60 00 00 70 cf eb 40 00      08:36:10.874  READ FPDMA QUEUED
  60 10 10 60 cf eb 40 00      08:36:10.873  READ FPDMA QUEUED
  60 10 08 50 cf eb 40 00      08:36:10.873  READ FPDMA QUEUED
  60 10 00 40 cf eb 40 00      08:36:10.873  READ FPDMA QUEUED
  60 80 48 a0 ce eb 40 00      08:36:10.562  READ FPDMA QUEUED
# 1  Short offline       Completed without error       00%      1072         -
# 2  Short offline       Completed without error       00%      1059         -
# 3  Short offline       Completed without error       00%       989         -
# 4  Short offline       Completed without error       00%       821         -
# 5  Short offline       Completed without error       00%       581         -
# 6  Short offline       Completed without error       00%       416         -
# 7  Extended offline    Completed without error       00%       358         -
# 8  Short offline       Completed without error       00%       248         -
Seems there have been 6 hours since the last error (currently 1072 hours up and last error at 1066).
Keep an eye on the CRC number and if it goes above 21, you still have a problem.
giuseppe30
no error on console from 2 hours (when I cange the sata cable)
giuseppe30
ok, same result!
Local Time is:    Thu Jun 17 18:12:07 2021 CEST
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1126
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       72
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       72
194 Temperature_Celsius     0x0002   150   150   000    Old_age   Always       -       40 (Min/Max 23/57)
# 1  Short offline       Completed without error       00%      1126         -
# 2  Extended offline    Completed without error       00%      1097         -
# 3  Short offline       Completed without error       00%      1072         -
# 4  Short offline       Completed without error       00%      1059         -
# 5  Short offline       Completed without error       00%       989         -
# 6  Short offline       Completed without error       00%       821         -
# 7  Short offline       Completed without error       00%       581         -
# 8  Short offline       Completed without error       00%       416         -
# 9  Extended offline    Completed without error       00%       358         -
#10  Short offline       Completed without error       00%       248         -
