schnoodles
- Jan 10, 2020
Hey.
Just warning everyone that I built this NAS 4 years ago and havent touched it much so I am quite a bit out of the loop.
I am running a HP Gen8 with 4 5TB WD Green HDDs with the latest FreeNAS-11.2-U7
The HDD part on the Dashboard says Healthy for all disks.... How ever I am getting an error every few seconds
I ran smartctl -a /dev/ada2 and it returned all sorts of crazy..... (When it wants to work)
pastebin.com
Although most of the time I run it I just get
So I am assuming something very wrong is happening here....
I tried to run zpool status and I got
pastebin.com
So I am really a bit out of my depth here.
My question really is.
1. Is my HDD completely screwed? Should I kick it off a cliff?
2. If it is screwed should I just by a WD 5TB Blue (I heard they replaced Green. I only bought Green as that was meant to be the NAS HDD).
3. If I buy a new HDD can I just plug it in and the RAID will rectify it?
Device: /dev/ada2, ATA error count increased from 59693 to 60134
Fri, 10 Jan 2020 04:24:35 GMTI ran smartctl -a /dev/ada2 and it returned all sorts of crazy..... (When it wants to work)
smartctl -a /dev/ada2 - Pastebin.com
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org Read Device Identity failed: Input/output error A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
zpool status - Pastebin.com
