I received over the past few days notifications that my error count increased from 0 to 1 on three of my drives. Question I have is how concerned should I be? Results of the SMART test are below. All of the errors occurred "at disk power-on"
CRITICAL: June 24, 2017, 2:07 a.m. - Device: /dev/ada1, ATA error count increased from 0 to 1
CRITICAL: June 26, 2017, 12:37 a.m. - Device: /dev/ada0, ATA error count increased from 0 to 1
CRITICAL: June 29, 2017, 7:40 a.m. - Device: /dev/ada2, ATA error count increased from 0 to 1
########## SMART status report summary for all drives ########## +------+---------------+----+- ----+-----+-----+-------+-------+--------+------+----------+------+-------+ |Device|Serial |Temp|Power|Start|Spin |ReAlloc|Current|Offline |Seek |Total |High |Command| | | | |On |Stop |Retry|Sectors|Pending|Uncorrec|Errors|Seeks |Fly |Timeout| | | | |Hours|Count|Count| |Sectors|Sectors | | |Writes|Count | +------+---------------+----+-----+-----+-----+-------+-------+--------+------+----------+------+-------+ |ada0 |WD-WCC4NJANZTZ8| 34 |19336| 30| 0| 0| 0| 0| N/A| N/A| N/A| N/A| |ada1 |WD-WCC4NDZPHV7N| 35 |19336| 30| 0| 0| 0| 0| N/A| N/A| N/A| N/A| |ada2 |WD-WMC4N0F3P1YZ| 36 |19335| 30| 0| 0| 0| 0| N/A| N/A| N/A| N/A| |ada3 |WD-WCC4NEAUV8ND| 36 |19335| 30| 0| 0| 0| 0| N/A| N/A| N/A| N/A| |ada4 |WD-WMC4N0F3APUY| 35 |19335| 30| 0| 0| 0| 0| N/A| N/A| N/A| N/A| |ada5 |WD-WMC4N0F95M77| 35 |19335| 30| 0| 0| 0| 0| N/A| N/A| N/A| N/A| +------+---------------+----+-----+-----+-----+-------+-------+--------+------+----------+------+-------+ ########## SMART status report for ada0 drive (Western Digital Red: WD-WCC4NJANZTZ8) ########## smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 183 178 021 Pre-fail Always - 5816 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19336 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 203 194 Temperature_Celsius 0x0022 116 110 000 Old_age Always - 34 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 19255 hours (802 days + 7 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 10 51 08 d0 01 40 40 Error: IDNF at LBA = 0x004001d0 = 4194768 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 08 d0 01 40 40 08 5d+15:44:23.903 WRITE DMA Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Short offline Completed without error 00% 19211 - ########## SMART status report for ada1 drive (Western Digital Red: WD-WCC4NDZPHV7N) ########## smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 186 180 021 Pre-fail Always - 5675 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19336 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 203 194 Temperature_Celsius 0x0022 115 109 000 Old_age Always - 35 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 19208 hours (800 days + 8 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 10 51 08 d8 01 40 40 Error: IDNF at LBA = 0x004001d8 = 4194776 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 08 d8 01 40 40 08 3d+17:02:32.579 WRITE DMA Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Short offline Completed without error 00% 19210 - ########## SMART status report for ada2 drive (Western Digital Red: WD-WMC4N0F3P1YZ) ########## smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 185 179 021 Pre-fail Always - 5716 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19335 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 19 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 203 194 Temperature_Celsius 0x0022 114 108 000 Old_age Always - 36 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 ATA Error Count: 1 CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 occurred at disk power-on lifetime: 19334 hours (805 days + 14 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 10 51 08 28 02 40 40 Error: IDNF at LBA = 0x00400228 = 4194856 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 08 28 02 40 40 08 8d+22:43:28.932 WRITE DMA Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Short offline Interrupted (host reset) 10% 19210 - ########## SMART status report for ada3 drive (Western Digital Red: WD-WCC4NEAUV8ND) ########## smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 186 179 021 Pre-fail Always - 5691 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19335 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 21 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 222 194 Temperature_Celsius 0x0022 114 109 000 Old_age Always - 36 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 No Errors Logged Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Short offline Completed without error 00% 19210 - ########## SMART status report for ada4 drive (Western Digital Red: WD-WMC4N0F3APUY) ########## smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 187 179 021 Pre-fail Always - 5650 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19335 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 22 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 201 194 Temperature_Celsius 0x0022 115 109 000 Old_age Always - 35 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 No Errors Logged Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Short offline Completed without error 00% 19210 - ########## SMART status report for ada5 drive (Western Digital Red: WD-WMC4N0F95M77) ########## smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) SMART overall-health self-assessment test result: PASSED ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 185 176 021 Pre-fail Always - 5750 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 30 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 19335 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 30 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 26 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 219 194 Temperature_Celsius 0x0022 115 109 000 Old_age Always - 35 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 2 No Errors Logged Test_Description Status Remaining LifeTime(hours) LBA_of_first_error Short offline Completed without error 00% 19210 -
