Another windows permission problem
anodos
Sambassador
Okay. Let's deal with the problems we see. Assuming this isn't an LDAP environment, your local "users" group is colliding with "BUILTIN\users" and breaking mappings. You'll need to rename that group to something else. For instance "smb_users". Is the user with problems a member of "shared"?
tvo.psc
Renamed group to "smb_users" as suggested. Only two users in that group - user1 and user2. The share can be accessed from 3 of 4 PCs in my office using either user1 or user2 credentials. Cannot access share from 4th PC with either.
anodos
Sambassador
Can you post the output of net groupmap list
tvo.psc
net groupmap list
Environment LOGNAME is not defined. Trying anonymous access.
smb_users (S-1-5-21-1059828769-753519628-2512994261-1005) -> smb_users
private (S-1-5-21-1059828769-753519628-2512994261-1004) -> private
shared (S-1-5-21-1059828769-753519628-2512994261-1001) -> shared
anodos
Sambassador
net groupmap list
Can you issue a service samba_server restart
I'm curious what SMB version is running on the PCs. If you wouldn't mind, run up a PowerShell session as administrator on a working PC and execute the following two commands:
PS C:\> dir \\localhost\c$
The second command must be executed within about 10 seconds of executing the first command:
PS C:\> Get-SmbConnection -ServerName localhost
I'm really only interested in output from the second command. It should look something like the following:
ServerName  ShareName  UserName            Credential          Dialect  NumOpens
localhost   c$         DomainName\UserN... DomainName.Testi... 3.02     0
The Dialect is of interest. Repeat for the rogue PC.
tvo.psc
Working PC:
PS C:\WINDOWS\system32> Get-SmbConnection -ServerName localhost
localhost c$ PSCAUX\Thomas MicrosoftAccount\xxxxxx@hotmail.com 3.1.1 0
Rogue PC:
localhost c$ PSC-MASTER\Thomas PSC-MASTER\Thomas 3.1.1 0
localhost IPC$ PSC-MASTER\Thomas PSC-MASTER\Thomas 3.1.1 0
I wonder... For Windows 8 and above, Microsoft has been promoting their Microsoft account, which is based on an email address, over local Windows accounts. This caused samba authentication problems for FreeNAS.
On the working PC, Thomas logs in using his Microsoft account xxxxx@hotmail.com. This maps in FreeNAS to one of the two users User1 or User2. Thomas is authenticated via this mechanism.
On the rogue PC, Thomas appears to be a local PC account. Thomas is denied access to FreeNAS because there is no account Thomas on FreeNAS.
This post details the issue https://www.ixsystems.com/community/threads/microsoft-account-user-mapping.26277/
@tvo.psc Did you manage to get to the bottom of this? Curious to know if you resolved the issue.
tvo.psc
No, I never resolved the issue. FYI the rogue PC does have a microsoft user account and a local PC account, both as administrators. Could not access the freenas shares from either account. Tried suggestions in all the previous posts. Decided to stop beating my head against the wall for now.
Thanks for your time. Will post if I stumble upon a solution in the future.
