Am I boned, or super-boned?
Flaggro
I had the power go out yesterday, and upon restart FreeNAS is behaving strangely. I think that either the flash drive died or wiped itself, as when I attempt to map network drive the only things on the IP which identifies itself to the network as FREENAS are memorycard and usbstorage (pictured). Am I correct in hoping that a reinstall of FreeNAS on a different flash drive should be all I need to do to recover?
Pheran
A screenshot of a broken CIFS share is not helpful information. Please read the forum rules and post as much info as you can about your FreeNAS server and any errors it is generating. If you are correct about your boot device being bad, then you should just be able to reinstall FreeNAS on a new boot device and import your pool, though you'll have to redo all your FreeNAS settings if you don't have a backup of them.
SweetAndLow
Sweet'NASty
Can you access the freenas gui?
joeschmuck
Old Man
I think you are Super-Boned ;)
Just answering the question.
