All FreeNas Settings to new system
Tankyspanky
Hello all,
Is it possible to "backup" all Freenas settings and plugin settings and put that on a new system?
Its on a server tower now and needs to go to a desktop model.
Or is the best to redo all from scratch ?
thanx in advance
Aad
If you're planning to move over the drives in your pools where the jails (plugins) are, you would be able to restore your config from the existing server and have everything work as expected right away.
If you plan to leave the disks, it will depend on how you have set up your plugin jails (did you separate out the config?).
You can just move all the disks, including the boot pool, and it will just work. You may need to reconfigure networking, though, depending on the hardware on both servers.
Tankyspanky
oo oke thanx,
I just wanted to install fresh on the new "server" and bring over the drive pool (2 disc's)
There is 2.4TB data on it (i got it all as backup too on a external) but want the easy way :)
I gonna try and swap it all Wednesday
