This is all on a TS140
Xeon 1226 v3
24GB ECC RAM
4x 3TB WD RED running in Raid 10
I had disk errors, I wiped them all and started again because I thought it was something that I'd done.
This is the output from zpool status
Here's the smartctl output for one of the disks (they all output exactly the same results)
I've read a few other threads that reference bad SATA connections, but as the errors are on all disks I'm not sure it's that.
Any help would be wonderful.
Xeon 1226 v3
24GB ECC RAM
pool: tank state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://illumos.org/msg/ZFS-8000-8A scan: scrub repaired 0 in 0h21m with 12 errors on Sun Feb 21 10:07:12 2016 config: NAME STATE READ WRITE CKSUM tank DEGRADED 0 0 91 mirror-0 DEGRADED 0 0 100 gptid/9e0c76e5-d6e2-11e5-b203-6c0b8408f021 DEGRADED 0 0 100 too many errors gptid/9eba2dbf-d6e2-11e5-b203-6c0b8408f021 DEGRADED 0 0 100 too many errors mirror-1 DEGRADED 0 0 82 gptid/9f714294-d6e2-11e5-b203-6c0b8408f021 DEGRADED 0 0 82 too many errors gptid/a032be8e-d6e2-11e5-b203-6c0b8408f021 DEGRADED 0 0 82 too many errors errors: 20 data errors, use '-v' for a list
SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 842 - # 2 Short offline Completed without error 00% 787 - # 3 Short offline Completed without error 00% 787 - # 4 Short offline Completed without error 00% 775 - # 5 Short offline Completed without error 00% 763 - # 6 Short offline Completed without error 00% 751 - # 7 Short offline Completed without error 00% 739 - # 8 Short offline Completed without error 00% 727 - # 9 Short offline Completed without error 00% 715 - #10 Short offline Completed without error 00% 704 - #11 Short offline Completed without error 00% 703 - #12 Short offline Completed without error 00% 691 - #13 Short offline Completed without error 00% 679 - #14 Short offline Completed without error 00% 667 - #15 Short offline Completed without error 00% 655 - #16 Short offline Completed without error 00% 643 - #17 Short offline Completed without error 00% 631 - #18 Short offline Completed without error 00% 622 - #19 Short offline Completed without error 00% 621 - #20 Short offline Completed without error 00% 620 - #21 Short offline Completed without error 00% 619 -
