SOLVED Alert on 9.10 (LSI HBA 9300-8i) Firmware does not match driver... can't solve it
m00nraker
Hi guys.
Problem with my 9.10 setup, showing LSI HBA driver/firmware misatch alert. Can't solve it, maybe a bug, idk.?!
I'm using a Supermicro X10SLH-7 and an AVAGO LSI 9300-8i HBA in it-mode.
This 9300 HBA has installed the Phase 9 (= P9) package for Firmware and BIOS, means:
Firmware Version 9.00, BIOS Version 8.21.
After applying the latest FreeNAS update via the gui I got a yellow blinking alert:
Firmware version 9 does not match driver version 13 for /dev/mpr0. Please flash controller to P13 IT firmware.
I checked the Avagotech support page for new Firmware and BIOS files:
These packs are currently availabe: P9 (is installed on HBA), P10, P11 and P12 (= latest)
But the alert said, P13 is needed. So I decided to install P12, the latest pack from the Avagotech page.
The HBA has now Firmware Version 12.00, BIOS Version 8.29
After booting FreeNAS a new alert showed up:
Firmware version 12 does not match driver version 13 for /dev/mpr0. Please flash controller to P13 IT firmware.
Problem is, there is no P13 IT firmware available for this 9300-8i HBA.
What can I do now? Maybe a bug with the last FreeNAS Update?
Need help please.
Cheers, Kai
Additional information:
sas3flash -listall
Avago Technologies SAS3 Flash Utility
Version 10.00.00.01 (2015.06.18)
Copyright 2008-2015 Avago Technologies. All rights reserved.
Adapter Selected is a Avago SAS: SAS3008(C0)
Num Ctlr FW Ver NVDATA x86-BIOS PCI Addr
0 SAS3008(C0) 12.00.00.00 0b.02.00.07 08.29.00.00 00:01:00:00
Finished Processing Commands Successfully.
Exiting SAS3Flash.
Seriously, LSI? Fscking seriously? God damn it, I feel like giving up. They literally would only need to skip a damned version number, but instead they decide that offsetting the version numbers for the driver and firmware by one was the better solution???
Marcet
Have to flash also. Thanks for sharing.
