mloiterman
- Jan 30, 2013
- motherboard make and model
- SuperMicro X11SSH-CTF
- CPU make and model
- Intel(R) Xeon(R) CPU E3-1275 v5 @ 3.60GHz (8 cores)
- RAM quantity
- 32 GiB
- hard drives, quantity, model numbers, and RAID configuration
- 8 x ST4000LM024
- RAIDZ2
- hard disk controllers
- Avago Technologies (LSI) SAS3008
- network cards
- None - using on board networking
- FreeNAS-11.2-RELEASE (Build Date: Dec 5, 2018 21:28)
Section 2.5.1 of 11.2 Manual suggests "Upgrading the firmware of Broadcom SAS HBAs to the latest version..."
In connection with this recommendation, I investigated my firmware version and have found:
root@marshall:/ # sas3flash -list Avago Technologies SAS3 Flash Utility Version 16.00.00.00 (2017.05.02) Copyright 2008-2017 Avago Technologies. All rights reserved. Adapter Selected is a Avago SAS: SAS3008(C0) Controller Number : 0 Controller : SAS3008(C0) PCI Address : 00:01:00:00 SAS Address : 5003048-0-1e04-6000 NVDATA Version (Default) : 0b.02.31.27 NVDATA Version (Persistent) : 0b.02.31.27 Firmware Product ID : 0x2721 (IR) Firmware Version : 12.00.02.00 NVDATA Vendor : LSI NVDATA Product ID : LSI3008-IR BIOS Version : 08.29.01.00 UEFI BSD Version : 14.00.00.00 FCODE Version : N/A Board Name : LSI3008-IR Board Assembly : N/A Board Tracer Number : N/A Finished Processing Commands Successfully. Exiting SAS3Flash.
It appears, based on Broadcom website (https://www.broadcom.com/products/storage/host-bus-adapters/sas-9300-8i#downloads), that latest version of firmware is 16.00.01.00 and the latest version of the FreeBSD drive is 20.00.00.00. So my firmware and driver are both out of date. But, my understanding is that driver comes from FreeNAS.
I've already upgraded my server to 11.2 without any issue and everything appears to be working correctly, so my thought is to leave well enough alone, but I'm wondering if I should still upgrade.
If so, there really doesn't appear to be very good or detailed instructions anywhere on Broadcom's site. They seem to indicate you can do it with the sas3flash utility, but it's not clear if I have to boot into the UEFI mode from the motherboard or if it can be done on a running system, say from within FreeNAS. It's really poorly documented and prior to undertaking this, I would like to see if there is any comment from the board on how to proceed.
