Jost Wittmann
- Feb 23, 2014
Hi!
I installed freenas 9.2 a while ago, and I am still trying to get the hang of it. I am experiencing several problems - not sure if they are connected...
I would like to use timemachine to backup a macbook pro (OsX 10.9.1). So I followed the freenas guide and created a user "dejhost" and a homedirectory "tm_dejhost". I also create a group, but I am unable to change the group of my user from "nobody" to the new group :-(
Trying to connect timemachine from the macbook to the afp-server, I received an error on the macbook:
Two questions:
1) In the serverlog above: I see that the user home doesn't match basedir regex... which is still "tm_dejhost". How can I fix this?
2) Also in the serverlog above: Why does it say "unexpected EOF"?
I hope somebody takes the time to point me in the right direction. There are quite a few things here I don't understand yet.
Thanks in advance.
P.s.: Now, the logfile displays also
SMART values do no list any malfunctioning of the drive. Do I need to replace the disk?
Searching the web for help I figured that the best thing to do is to start over. This time I named the homedirectory "tmdejhost"... receiving the same error (only the name of the backup disk changed) and the following log file from the server:Time Machine can’t access the backup disk “tm_dejhost”. The operation couldn’t be completed. (OSStatus error 2.)
Feb 23 19:18:57 Jonas afpd[11693]: AFP3.3 Login by dejhost Feb 23 19:18:57 Jonas afpd[11693]: readvolfile: user home "/mnt/Backup1tb/tmdejhost" doesn't match basedir regex "/mnt/Backup1tb/tm_dejhost" Feb 23 19:18:57 Jonas afpd[11693]: AFP logout by dejhost Feb 23 19:18:57 Jonas afpd[11693]: dsi_stream_read: len:0, unexpected EOF Feb 23 19:18:57 Jonas afpd[11693]: afp_over_dsi: client logged out, terminating DSI session Feb 23 19:18:57 Jonas afpd[11693]: AFP statistics: 0.60 KB read, 0.45 KB written Feb 23 19:19:49 Jonas notifier: Performing sanity check on Samba configuration: OK Feb 23 19:19:49 Jonas notifier: Stopping avahi-daemon. Feb 23 19:21:03 Jonas afpd[14213]: AFP3.3 Login by dejhost Feb 23 19:21:03 Jonas afpd[14213]: readvolfile: user home "/mnt/Backup1tb/tmdejhost" doesn't match basedir regex "/mnt/Backup1tb/tm_dejhost" Feb 23 19:21:03 Jonas afpd[14213]: AFP logout by dejhost Feb 23 19:21:03 Jonas afpd[14213]: dsi_stream_read: len:0, unexpected EOF Feb 23 19:21:03 Jonas afpd[14213]: afp_over_dsi: client logged out, terminating DSI session Feb 23 19:21:03 Jonas afpd[14213]: AFP statistics: 0.60 KB read, 0.45 KB written Feb 23 19:23:41 Jonas notifier: Stopping inetd. Feb 23 19:23:41 Jonas notifier: Waiting for PIDS: 3406. Feb 23 19:23:41 Jonas notifier: Will not 'restart' inetd because inetd_enable is NO.
Two questions:
Thanks in advance.
Feb 24 19:10:24 Jonas smartd[2267]: Device: /dev/ada2, 4 Currently unreadable (pending) sectors Feb 24 19:10:24 Jonas smartd[2267]: Device: /dev/ada2, 4 Offline uncorrectable sectors
