gegtor
- Sep 16, 2017
Here is my uptime chart as you can see my system is crashing very frequently
Here is my hardware info:
CPU: AMD Ryzen 1700
MB: MSI Gaming Pro B350M
RAM: Generic 2 x 8GB 2400mHz non-ECC
GPU: AMD RX 550
Boot: Kingston SSD 120GB A400
Storage: 2 x WD RED 1TB
Here is my use case:
4 computer connected using AFP and putting light load (only documents)
3 running VM's each 2GB RAM and 1 CPU
How it crashes:
Whole server just hangs leaving no info in Kernel log or anything
Boots up normally without any errors after pushing reset button
/var/log/messages before crash
![Xzv5qun.png](https://i.imgur.com/Xzv5qun.png)
CPU: AMD Ryzen 1700
GPU: AMD RX 550
How it crashes:
Feb 9 08:50:59 SKA-SERVER afpd[95711]: Login by PReifur (AFP3.4) Feb 9 10:03:54 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 10:18:54 SKA-SERVER afpd[1604]: Login by VAndriyants (AFP3.4) Feb 9 10:18:56 SKA-SERVER afpd[32854]: Disconnected session terminating Feb 9 10:18:56 SKA-SERVER afpd[4870]: Terminated disconnected child[32854], client rebooted. Feb 9 11:04:32 SKA-SERVER afpd[95711]: AFP logout by PReifur Feb 9 11:04:32 SKA-SERVER afpd[95711]: AFP statistics: 38212.43 KB read, 79134.44 KB written Feb 9 11:04:32 SKA-SERVER afpd[95711]: done Feb 9 11:20:02 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 11:33:12 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 13:05:55 SKA-SERVER afpd[1604]: afp_zzz: entering extended sleep Feb 9 13:17:35 SKA-SERVER daemon[3266]: ==> Newer Consul version available: 1.0.5 (currently running: 1.0.0) Feb 9 13:26:00 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 13:26:44 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 13:44:04 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 13:44:38 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 14:24:04 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 14:24:59 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 14:26:31 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 14:34:18 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 15:15:55 SKA-SERVER afpd[1604]: read: Operation timed out Feb 9 15:15:55 SKA-SERVER afpd[1604]: dsi_stream_read: len:-1, Operation timed out Feb 9 15:15:55 SKA-SERVER afpd[1604]: dsi_disconnect: entering disconnected state Feb 9 17:06:28 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 17:13:51 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 17:27:29 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 17:37:13 SKA-SERVER afpd[29874]: Login by VAndriyants (AFP3.4) Feb 9 17:37:16 SKA-SERVER afpd[1604]: Disconnected session terminating Feb 9 17:37:16 SKA-SERVER afpd[4870]: Terminated disconnected child[1604], client rebooted. Feb 9 17:41:44 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 17:52:49 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 17:56:00 SKA-SERVER afpd[8992]: afp_zzz: waking up from extended sleep Feb 9 18:04:43 SKA-SERVER afpd[29874]: read: Connection reset by peer Feb 9 18:04:43 SKA-SERVER afpd[29874]: dsi_stream_read: len:-1, Connection reset by peer Feb 9 18:04:43 SKA-SERVER afpd[29874]: dsi_disconnect: entering disconnected state Feb 9 18:04:58 SKA-SERVER afpd[31752]: Login by VAndriyants (AFP3.4) Feb 9 18:05:00 SKA-SERVER afpd[29874]: Disconnected session terminating Feb 9 18:05:00 SKA-SERVER afpd[4870]: Terminated disconnected child[29874], client rebooted. Feb 9 18:08:58 SKA-SERVER afpd[31752]: afp_alarm: child timed out, entering disconnected state Feb 9 18:08:58 SKA-SERVER afpd[31752]: dsi_disconnect: entering disconnected state Feb 9 18:08:58 SKA-SERVER afpd[31752]: dsi_disconnect: entering disconnected state Feb 9 18:21:06 SKA-SERVER afpd[8992]: afp_zzz: entering extended sleep Feb 9 23:41:55 SKA-SERVER afpd[57938]: afp_alarm: reconnect timer expired, goodbye Feb 9 23:41:55 SKA-SERVER afpd[57938]: Disconnected session terminating
