[SOLVED] Time Machine doesn't find AFP share. Help please!!!
Hugo Ochoa
I've setup FreeNas 9.2.1.5 x 64 following the manual's instructions. However, my
MacBookPro 11,3 Mavericks System Version: OS X 10.9.4 (13E28) Kernel Version: Darwin 13.3.0 doesn't want to find the AFP share I've setup for Time Machine. I get an error saying: No configured AirPort base stations have been found. AirPort Utility will continue searching.
The shares I've setup are available when I connect to the server using Finder. It's just Time Machine not finding any available shares/drives in the network.
Here's a log from FreeNas:
Jul 11 02:51:38 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 02:51:38 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 02:51:38 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 03:07:40 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 03:07:40 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 03:07:40 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 03:23:42 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 03:23:42 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 03:23:42 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 03:38:40 freenas afpd[65190]: Login by nobody (AFP3.4)
Jul 11 03:38:40 freenas afpd[65190]: afp_disconnect: trying primary reconnect
Jul 11 03:38:40 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 03:38:40 freenas afpd[54472]: Reconnect: killing new session child[65190] after transfer
Jul 11 03:38:40 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 03:38:40 freenas afpd[54529]: AFP Replay Cache match: id: 23580 / cmd: AFP_GETEXTATTR
Jul 11 03:38:40 freenas afpd[54529]: AFP Replay Cache match: id: 23581 / cmd: AFP_GETFLDRPARAM
Jul 11 03:38:41 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 03:38:42 freenas afpd[65190]: afp_disconnect: primary reconnect succeeded
Jul 11 03:39:44 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 03:39:44 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 03:39:44 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 03:49:36 freenas afpd[54529]: read: Operation timed out
Jul 11 03:49:36 freenas afpd[54529]: dsi_stream_read: len:-1, Operation timed out
Jul 11 03:49:36 freenas afpd[54529]: dsi_stream_read: len:0, unexpected EOF
Jul 11 03:49:36 freenas afpd[54529]: dsi_disconnect: entering disconnected state
Jul 11 03:55:46 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 03:55:46 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 03:55:46 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 04:11:48 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 04:11:48 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 04:11:48 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 04:27:50 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 04:27:50 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 04:27:50 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 04:43:00 freenas afpd[66632]: Login by nobody (AFP3.4)
Jul 11 04:43:00 freenas afpd[66632]: afp_disconnect: trying primary reconnect
Jul 11 04:43:00 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 04:43:00 freenas afpd[54472]: Reconnect: killing new session child[66632] after transfer
Jul 11 04:43:00 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 04:43:00 freenas afpd[54529]: AFP Replay Cache match: id: 42767 / cmd: AFP_GETFLDRPARAM
Jul 11 04:43:01 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 04:43:02 freenas afpd[66632]: afp_disconnect: primary reconnect succeeded
Jul 11 04:43:52 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 04:43:52 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 04:43:52 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 04:51:36 freenas afpd[54529]: read: Operation timed out
Jul 11 04:51:36 freenas afpd[54529]: dsi_stream_read: len:-1, Operation timed out
Jul 11 04:51:36 freenas afpd[54529]: dsi_stream_read: len:0, unexpected EOF
Jul 11 04:51:36 freenas afpd[54529]: dsi_disconnect: entering disconnected state
Jul 11 04:59:54 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 04:59:54 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 04:59:54 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 05:15:56 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 05:15:56 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 05:15:56 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 05:31:58 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 05:31:58 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 05:31:58 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 05:44:32 freenas afpd[67942]: Login by nobody (AFP3.4)
Jul 11 05:44:32 freenas afpd[67942]: afp_disconnect: trying primary reconnect
Jul 11 05:44:32 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 05:44:32 freenas afpd[54472]: Reconnect: killing new session child[67942] after transfer
Jul 11 05:44:32 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 05:44:32 freenas afpd[54529]: AFP Replay Cache match: id: 23504 / cmd: AFP_GETEXTATTR
Jul 11 05:44:32 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 05:44:34 freenas afpd[67942]: afp_disconnect: primary reconnect succeeded
Jul 11 05:48:00 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 05:48:00 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 05:48:00 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 05:52:35 freenas afpd[54529]: read: Operation timed out
Jul 11 05:52:35 freenas afpd[54529]: dsi_stream_read: len:-1, Operation timed out
Jul 11 05:52:35 freenas afpd[54529]: dsi_stream_read: len:0, unexpected EOF
Jul 11 05:52:35 freenas afpd[54529]: dsi_disconnect: entering disconnected state
Jul 11 06:04:02 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 06:04:02 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 06:04:02 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 06:20:04 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 06:20:04 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 06:20:04 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 06:36:06 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 06:36:06 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 06:36:06 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 06:45:34 freenas afpd[69270]: Login by nobody (AFP3.4)
Jul 11 06:45:34 freenas afpd[69270]: afp_disconnect: trying primary reconnect
Jul 11 06:45:34 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 06:45:34 freenas afpd[54472]: Reconnect: killing new session child[69270] after transfer
Jul 11 06:45:34 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 06:45:34 freenas afpd[54529]: AFP Replay Cache match: id: 62476 / cmd: AFP_GETEXTATTR
Jul 11 06:45:34 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 06:45:36 freenas afpd[69270]: afp_disconnect: primary reconnect succeeded
Jul 11 06:52:08 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 06:52:08 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 06:52:08 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 06:54:10 freenas afpd[54529]: read: Operation timed out
Jul 11 06:54:10 freenas afpd[54529]: dsi_stream_read: len:-1, Operation timed out
Jul 11 06:54:10 freenas afpd[54529]: dsi_stream_read: len:0, unexpected EOF
Jul 11 06:54:10 freenas afpd[54529]: dsi_disconnect: entering disconnected state
Jul 11 07:05:40 freenas afpd[69731]: Login by nobody (AFP3.4)
Jul 11 07:05:40 freenas afpd[69731]: afp_disconnect: trying primary reconnect
Jul 11 07:05:40 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 07:05:40 freenas afpd[54472]: Reconnect: killing new session child[69731] after transfer
Jul 11 07:05:40 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 07:05:40 freenas afpd[54529]: AFP Replay Cache match: id: 40386 / cmd: AFP_GETEXTATTR
Jul 11 07:05:42 freenas afpd[69731]: afp_disconnect: primary reconnect succeeded
Jul 11 07:08:10 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 07:08:10 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 07:08:10 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 07:16:59 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 07:22:23 freenas afpd[54529]: read: Operation timed out
Jul 11 07:22:23 freenas afpd[54529]: dsi_stream_read: len:-1, Operation timed out
Jul 11 07:22:23 freenas afpd[54529]: dsi_stream_read: len:0, unexpected EOF
Jul 11 07:22:23 freenas afpd[54529]: dsi_disconnect: entering disconnected state
Jul 11 07:22:42 freenas afpd[70463]: Login by nobody (AFP3.4)
Jul 11 07:22:42 freenas afpd[70463]: afp_disconnect: trying primary reconnect
Jul 11 07:22:42 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 07:22:42 freenas afpd[54472]: Reconnect: killing new session child[70463] after transfer
Jul 11 07:22:42 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 07:22:42 freenas afpd[54529]: AFP Replay Cache match: id: 63019 / cmd: AFP_GETEXTATTR
Jul 11 07:22:42 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 07:22:44 freenas afpd[70463]: afp_disconnect: primary reconnect succeeded
Jul 11 07:23:07 freenas afpd[70478]: Login by nobody (AFP3.4)
Jul 11 07:23:07 freenas afpd[70478]: afp_disconnect: trying primary reconnect
Jul 11 07:23:07 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 07:23:07 freenas afpd[54472]: Reconnect: killing new session child[70478] after transfer
Jul 11 07:23:07 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 07:23:07 freenas afpd[54529]: AFP Replay Cache match: id: 64651 / cmd: AFP_GETEXTATTR
Jul 11 07:23:09 freenas afpd[70478]: afp_disconnect: primary reconnect succeeded
Jul 11 07:24:12 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 07:24:12 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 07:24:12 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 07:37:43 freenas afpd[54529]: afp_zzz: entering extended sleep
Jul 11 07:40:14 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 07:40:14 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 07:40:14 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 07:56:16 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 07:56:16 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 07:56:16 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 08:12:18 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 08:12:18 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 08:12:18 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 08:28:20 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 08:28:20 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 08:28:20 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 08:30:13 freenas afpd[76389]: Login by nobody (AFP3.4)
Jul 11 08:30:13 freenas afpd[76389]: afp_disconnect: trying primary reconnect
Jul 11 08:30:13 freenas afpd[54472]: Reconnect: transfering session to child[54529]
Jul 11 08:30:13 freenas afpd[54472]: Reconnect: killing new session child[76389] after transfer
Jul 11 08:30:13 freenas afpd[54529]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 08:30:15 freenas afpd[76389]: afp_disconnect: primary reconnect succeeded
Jul 11 08:31:36 freenas afpd[54529]: AFP logout by nobody
Jul 11 08:31:36 freenas afpd[54529]: AFP statistics: 88579073.02 KB read, 440062.81 KB written
Jul 11 08:31:36 freenas afpd[54529]: done
Jul 11 08:44:22 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 08:44:22 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 08:44:22 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 08:44:49 freenas mountd[3024]: mount request denied from 10.0.0.11 for /
Jul 11 08:46:44 freenas mountd[3024]: mount request from 10.0.0.11 for non existent path /mnt/tvol2/UnixShares
Jul 11 08:46:44 freenas mountd[3024]: mount request denied from 10.0.0.11 for /mnt/tvol2/UnixShares
Jul 11 08:46:46 freenas afpd[77017]: Login by Hugo (AFP3.4)
Jul 11 08:46:55 freenas afpd[77017]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 08:46:55 freenas cnid_dbd[77020]: main: fatal db lock error
Jul 11 08:46:55 freenas cnid_dbd[77020]: Failed to open CNID database for volume "freenas"
Jul 11 08:46:55 freenas cnid_dbd[77020]: Recreated CNID BerkeleyDB databases of volume "freenas"
Jul 11 08:47:12 freenas last message repeated 11 times
Jul 11 08:49:12 freenas last message repeated 8 times
Jul 11 08:51:13 freenas last message repeated 8 times
Jul 11 08:51:33 freenas afpd[77017]: afp_zzz: entering extended sleep
Jul 11 08:51:42 freenas afpd[77017]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 08:51:52 freenas last message repeated 3 times
Jul 11 08:53:53 freenas afpd[77212]: Login by Hugo (AFP3.4)
Jul 11 08:53:53 freenas afpd[77212]: afp_disconnect: trying primary reconnect
Jul 11 08:53:53 freenas afpd[54472]: Reconnect: transfering session to child[77017]
Jul 11 08:53:53 freenas afpd[54472]: Reconnect: killing new session child[77212] after transfer
Jul 11 08:53:53 freenas afpd[77017]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 08:53:55 freenas afpd[77212]: afp_disconnect: primary reconnect succeeded
Jul 11 08:54:06 freenas afpd[77017]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 08:54:36 freenas last message repeated 5 times
Jul 11 08:56:36 freenas last message repeated 8 times
Jul 11 08:58:06 freenas last message repeated 6 times
Jul 11 08:58:08 freenas afpd[77017]: afp_zzz: entering extended sleep
Jul 11 08:58:27 freenas afpd[77017]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 09:00:02 freenas autosnap.py: [tools.autosnap:58] Popen()ing: /sbin/zfs snapshot tvol1/WinShare@auto-20140711.0900-2w
Jul 11 09:00:02 freenas autosnap.py: [tools.autosnap:58] Popen()ing: /sbin/zfs snapshot tvol2/UnixShare@auto-20140711.0900-2w
Jul 11 09:00:03 freenas autosnap.py: [tools.autosnap:58] Popen()ing: /sbin/zfs snapshot tvol2/AppleShare@auto-20140711.0900-2w
Jul 11 09:00:24 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 09:00:24 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 09:00:24 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 09:02:24 freenas afpd[77520]: Login by Hugo (AFP3.4)
Jul 11 09:02:24 freenas afpd[77520]: afp_disconnect: trying primary reconnect
Jul 11 09:02:24 freenas afpd[54472]: Reconnect: transfering session to child[77017]
Jul 11 09:02:24 freenas afpd[54472]: Reconnect: killing new session child[77520] after transfer
Jul 11 09:02:24 freenas afpd[77017]: afp_dsi_transfer_session: succesfull primary reconnect
Jul 11 09:02:26 freenas afpd[77520]: afp_disconnect: primary reconnect succeeded
Jul 11 09:02:27 freenas afpd[77017]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 09:02:57 freenas last message repeated 3 times
Jul 11 09:04:57 freenas last message repeated 8 times
Jul 11 09:10:27 freenas last message repeated 22 times
Jul 11 09:10:49 freenas notifier: Stopping netatalk.
Jul 11 09:10:49 freenas cnid_metad[54473]: shutting down on SIGTERM
Jul 11 09:10:49 freenas afpd[54472]: AFP Server shutting down
Jul 11 09:10:49 freenas cnid_dbd[77020]: error closing database name.db: DB_RUNRECOVERY: Fatal error, run database recovery
Jul 11 09:10:49 freenas afpd[77017]: AFP statistics: 19.69 KB read, 19.37 KB written
Jul 11 09:10:49 freenas cnid_dbd[77020]: error closing database didname.db: DB_RUNRECOVERY: Fatal error, run database recovery
Jul 11 09:10:49 freenas netatalk[54471]: Netatalk AFP server exiting
Jul 11 09:10:49 freenas cnid_dbd[77020]: error closing database devino.db: DB_RUNRECOVERY: Fatal error, run database recovery
Jul 11 09:10:49 freenas cnid_dbd[77020]: error closing database cnid2.db: DB_RUNRECOVERY: Fatal error, run database recovery
Jul 11 09:10:49 freenas cnid_dbd[77020]: error closing DB environment: DB_RUNRECOVERY: Fatal error, run database recovery
Jul 11 09:10:49 freenas notifier: Waiting for PIDS: 54471.
Jul 11 09:10:49 freenas notifier: Starting netatalk.
Jul 11 09:10:49 freenas netatalk[78807]: Netatalk AFP server starting
Jul 11 09:10:49 freenas cnid_metad[78809]: CNID Server listening on localhost:4700
Jul 11 09:10:50 freenas afpd[78808]: Netatalk AFP/TCP listening on 10.0.0.200:548
Jul 11 09:10:59 freenas notifier: Stopping netatalk.
Jul 11 09:10:59 freenas cnid_metad[78809]: shutting down on SIGTERM
Jul 11 09:10:59 freenas afpd[78808]: AFP Server shutting down
Jul 11 09:10:59 freenas netatalk[78807]: Netatalk AFP server exiting
Jul 11 09:10:59 freenas notifier: Waiting for PIDS: 78807.
Jul 11 09:10:59 freenas notifier: Will not 'start' netatalk because netatalk_enable is NO.
Jul 11 09:11:01 freenas notifier: netatalk not running?
Jul 11 09:11:01 freenas notifier: Starting netatalk.
Jul 11 09:11:01 freenas netatalk[79139]: Netatalk AFP server starting
Jul 11 09:11:01 freenas cnid_metad[79141]: CNID Server listening on localhost:4700
Jul 11 09:11:02 freenas afpd[79140]: Netatalk AFP/TCP listening on 10.0.0.200:548
Jul 11 09:11:10 freenas notifier: Stopping netatalk.
Jul 11 09:11:10 freenas cnid_metad[79141]: shutting down on SIGTERM
Jul 11 09:11:10 freenas afpd[79140]: AFP Server shutting down
Jul 11 09:11:10 freenas netatalk[79139]: Netatalk AFP server exiting
Jul 11 09:11:10 freenas notifier: Waiting for PIDS: 79139.
Jul 11 09:11:10 freenas notifier: Starting netatalk.
Jul 11 09:11:10 freenas netatalk[80140]: Netatalk AFP server starting
Jul 11 09:11:10 freenas cnid_metad[80142]: CNID Server listening on localhost:4700
Jul 11 09:11:10 freenas afpd[80141]: Netatalk AFP/TCP listening on 10.0.0.200:548
Jul 11 09:11:50 freenas afpd[80146]: Login by Hugo (AFP3.4)
Jul 11 09:11:53 freenas afpd[80146]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 09:12:27 freenas last message repeated 10 times
Jul 11 09:14:28 freenas last message repeated 8 times
Jul 11 09:15:58 freenas last message repeated 7 times
Jul 11 09:16:26 freenas ntpd_initres[3506]: host name not found: 0.freebsd.pool.ntp.org
Jul 11 09:16:26 freenas ntpd_initres[3506]: host name not found: 1.freebsd.pool.ntp.org
Jul 11 09:16:26 freenas ntpd_initres[3506]: host name not found: 2.freebsd.pool.ntp.org
Jul 11 09:16:28 freenas afpd[80146]: sys_lsetxattr("/mnt/tvol2/AppleShare/TimeMachine/."): Permission denied
Jul 11 09:18:28 freenas last message repeated 8 times
Jul 11 09:28:58 freenas last message repeated 46 times
Any help would be greatly appreciated!
Robert Trevellyan
Pony Wrangler
Did you check the Time Machine box in the relevant AFP share settings? That's the only extra thing I had to do to get Time Machine to see it.
Not sure what role AirPort Utility has to play in this. It wasn't part of my process when setting up Time Machine destinations in FreeNAS.
Hugo Ochoa
Thanks for your response Robert. What version of OSX and freenas are you running? I'm going to System Preferences and click on Time Machine. A window shows up that is the same as in the freenas manual. then I click on the on switch and a drop down window shows me the option to "Other Time Capsule" as the only option. I then get a window where it seems to be searching for something and then after a few seconds it says "No configured AirPort base stations...".
I followed the FreeNAS manual steps closely and did it over a couple of times but still cannot get time machine working.
Robert Trevellyan
Pony Wrangler
OS X 10.9.4 Mavericks, FreeNAS-9.2.1.5-RELEASE-x64 (80c1d35).
When I check the Time Machine setting on an AFP share, then I go to Time Machine Preferences on the Mac and click Select Disk, it shows up under Available Disks.
Hugo Ochoa
I've finally figured out the problem. I had my freenas server turned off until today and when I checked the permissions on the Time Machine share I had created, it was still set for root only. It's probably an obvious thing for most but it is important to connect to the freenas server in Finder before you try to setup Time Machine. Thanks to Robert Trevellyan for his replies.
