AFP Broken after 8.0.1 B4?
I believe that there is a new AFP bug from the jump from 8.0.1 Beta 4 to 8.0.1 RC1 and RC2. After a fresh install of 8.0.1 RC1 AFP would act awkwardly with Time Machine. Time Machine would try to perform an hourly backup and after a arbitrary amount of time the back up would seem to have completed, but either "failed" in the background or I would actually receive an error from TM that it failed. If the backup "failed" in the background the next hourly backup would be the same size as the previous. This morning I fresh installed 8.0.1 RC2 but AFP seems to still be broken.... Here is some CLI output with viewing AFP settings...
Following output is after boot:
Sep 24 13:51:58 wildebeast proftpd[1623]: 127.0.0.1 - ProFTPD 1.3.3e (maint) (built Fri Sep 16 2011 20:42:35 UTC) standalone mode STARTUP
Sep 24 13:51:59 wildebeast avahi-daemon[1679]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sep 24 13:51:59 wildebeast cnid_metad[1689]: Set syslog logging to level: LOG_NOTE
Sep 24 13:51:59 wildebeast [1691]: Set syslog logging to level: LOG_NOTE
Sep 24 13:51:59 wildebeast afpd[1692]: AFP/TCP started, advertising 98.111.***.***:548 (2.2.0)
Sep 24 13:52:02 wildebeast freenas[1705]: Popen()ing: zpool list -H -o health zebra
Sep 24 13:52:04 wildebeast INADYN[1775]: I:INADYN: IP address for alias 'wildebeast.***.com' needs update to '98.111.***.***'
Sep 24 13:52:04 wildebeast INADYN[1775]: I:INADYN: Alias 'wildebeast.***.com' to IP '98.111.***.***' updated successful.
Sep 24 13:52:13 wildebeast ntpd[1459]: time reset +1.537455 s
Sep 24 13:55:02 wildebeast freenas[2317]: Popen()ing: zpool list -H -o health zebra
Why is AFP advertising on my external ip address?!
This next output is the response of disabling AFP via GUI
Sep 24 14:03:30 wildebeast freenas[1703]: Executing: /usr/sbin/service ix-afpd quietstart
Sep 24 14:03:30 wildebeast freenas[1703]: Executing: /usr/sbin/service netatalk forcestop
Sep 24 14:03:30 wildebeast afpd[1692]: AFP Server shutting down on SIGTERM
Sep 24 14:03:30 wildebeast freenas[1703]: Executing: /usr/sbin/service dbus forcestop
Sep 24 14:03:30 wildebeast freenas: Stopping dbus.
Sep 24 14:03:30 wildebeast avahi-daemon[1679]: Disconnected from D-Bus, exiting.
Sep 24 14:03:30 wildebeast freenas[1703]: Executing: /usr/sbin/service dbus restart
Sep 24 14:03:31 wildebeast freenas: dbus not running? (check /var/run/dbus/dbus.pid).
Sep 24 14:03:31 wildebeast freenas: Starting dbus.
Sep 24 14:03:31 wildebeast freenas[1703]: Executing: /usr/sbin/service avahi-daemon forcestop
Sep 24 14:03:31 wildebeast freenas: Stopping avahi-daemon.
Sep 24 14:03:31 wildebeast freenas: Failed to kill daemon: No such file or directory
Sep 24 14:03:31 wildebeast freenas[1703]: Executing: /usr/sbin/service avahi-daemon restart
Sep 24 14:03:31 wildebeast freenas: Starting avahi-daemon.
Sep 24 14:03:31 wildebeast avahi-daemon[2868]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sep 24 14:03:31 wildebeast freenas[1703]: Executing: /usr/sbin/service netatalk restart
Sep 24 14:03:31 wildebeast freenas: Will not 'restart' netatalk because netatalk_enable is NO.
Sep 24 14:03:31 wildebeast freenas[1703]: Executing: /bin/pgrep -F /var/run/afpd.pid afpd
Seems ok...
Next output is by restarting AFP from the GUI
Sep 24 14:07:52 wildebeast freenas[1703]: Executing: /usr/sbin/service netatalk restart
Sep 24 14:07:52 wildebeast freenas: No matching processes were found
Sep 24 14:07:52 wildebeast cnid_metad[3288]: Set syslog logging to level: LOG_NOTE
Sep 24 14:07:52 wildebeast [3290]: Set syslog logging to level: LOG_NOTE
Sep 24 14:07:52 wildebeast afpd[3291]: AFP/TCP started, advertising 98.111.***.***:548 (2.2.0)
Sep 24 14:07:52 wildebeast freenas[1703]: Executing: /bin/pgrep -F /var/run/afpd.pid afpd
Sep 24 14:07:53 wildebeast afpd[3291]: bind(fd, (struct sockaddr *)&address, address_length) failed: Address already in use
Sep 24 14:07:53 wildebeast ntpd[1459]: kernel time sync status change 2001
AFP enabled...I guess, but still using my external ip...
This is the result of either just viewing the AFP Shares Settings and selecting OK, or changing a setting:
Sep 24 14:09:35 wildebeast freenas[1703]: Executing: /usr/sbin/service ix-afpd quietstart
Sep 24 14:09:35 wildebeast freenas[1703]: Executing: /usr/sbin/service netatalk forcestop
Sep 24 14:09:35 wildebeast afpd[3291]: AFP Server shutting down on SIGTERM
Sep 24 14:09:35 wildebeast freenas[1703]: Executing: /usr/sbin/service dbus forcestop
Sep 24 14:09:36 wildebeast freenas: Stopping dbus.
Sep 24 14:09:36 wildebeast avahi-daemon[3273]: Disconnected from D-Bus, exiting.
Sep 24 14:09:36 wildebeast afpd[3291]: Failed to contact server: Daemon not running
Sep 24 14:09:36 wildebeast freenas[1703]: Executing: /usr/sbin/service dbus restart
Sep 24 14:09:36 wildebeast freenas: dbus not running? (check /var/run/dbus/dbus.pid).
Sep 24 14:09:36 wildebeast freenas: Starting dbus.
Sep 24 14:09:36 wildebeast freenas[1703]: Executing: /usr/sbin/service avahi-daemon forcestop
Sep 24 14:09:36 wildebeast freenas: Stopping avahi-daemon.
Sep 24 14:09:36 wildebeast freenas: Failed to kill daemon: No such file or directory
Sep 24 14:09:36 wildebeast freenas[1703]: Executing: /usr/sbin/service avahi-daemon restart
Sep 24 14:09:36 wildebeast freenas: Starting avahi-daemon.
Sep 24 14:09:36 wildebeast avahi-daemon[3522]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sep 24 14:09:36 wildebeast freenas[1703]: Executing: /usr/sbin/service netatalk restart
Sep 24 14:09:36 wildebeast freenas: No matching processes were found
Sep 24 14:09:36 wildebeast cnid_metad[3537]: Set syslog logging to level: LOG_NOTE
Sep 24 14:09:36 wildebeast [3539]: Set syslog logging to level: LOG_NOTE
Sep 24 14:09:36 wildebeast afpd[3540]: dsi_tcp_init: no suitable network config for TCP socket
Sep 24 14:09:36 wildebeast afpd[3540]: main: dsi_init: Address already in use
Sep 24 14:09:36 wildebeast freenas[1703]: Executing: /bin/pgrep -F /var/run/afpd.pid afpd
Sep 24 14:09:37 wildebeast freenas[1703]: Executing: /bin/pgrep -F /var/run/afpd.pid afpd
Sep 24 14:09:37 wildebeast afpd[3540]: ===============================================================
Sep 24 14:09:37 wildebeast afpd[3540]: INTERNAL ERROR: Signal 11 in pid 3540 (2.2.0)
Sep 24 14:09:38 wildebeast kernel: pid 3540 (afpd), uid 0: exited on signal 6
WOOPS! AFP returns Signal 11 & 6... But the GUI reports no errors...
Just to confirm the status of afpd this is what TOP reports:
last pid: 6228; load averages: 0.00, 0.04, 0.06 up 0+00:25:32
14:17:04 45 processes: 2 running, 43 sleeping
Mem: 95M Active, 31M Inact, 141M Wired, 4372K Cache, 138M Buf, 3627M Free Swap: 6144M Total, 6144M Free
PID USERNAME THR PRI NICE SIZE RES STATE TIME WCPU COMMAND
1703 root 6 44 0 113M 60600K uwait 0:05 0.00% python
3291 root 1 44 0 20452K 3476K uwrlck 0:01 0.00% afpd
afp reports uwrlck?
So I reboot since AFP "is locked..." After rebooting, I will try to connect using AFP by afp://192.168.5.2/Time-Machine which I should receive a prompt to enter a user name and password... but instead I get an error from Finder "Connection Failed, You do not have the permissions to access the server "192.168.5.2" But for this share the permissions are 770, and the owner is the correct account. No settings have changed because it has just worked... Anyway, back to the finder error...
The only option is to click OK, but then this happens over and over again, there is no option to specify a user name and password, and I can't click cancel to stop trying to connect because there isn't a cancel button.
For each time I click ok, the FreeNAS server reports that "Sep 24 15:10:22 wildebeast afpd[4680]: AFP3.3 Login by sharing" which is the correct user name.
Next, I try to log onto to the Time-Machine Share through setting up a TM disk.
I see the appropriate share and it is listed as a TM device. I am offered to enter a user name and password, I do so, and then I receive this...
"The operation could not be completed (OSStatus error 13)"
So for now since AFP seems to be broken after 8.0.1 B4, I have disabled AFP...
If you have any insight please share...
I'm using 10.6.8 btw...
Thanks in advance.
Seems ok...
afp reports uwrlck?
Thanks in advance.
