UncleFester
- Feb 8, 2016
Hello To You All,
I have managed to get myself in a state of backup befuddlement concerning my main computer.
It is a multiboot Win 8 machine. I want to backup this macine to my FreeNAS server.
It has 4 instances of Win 8 installed as follows:
1. DAW OS (configured especially for making music).
2. General OS (for day to day stuff).
3. Test OS (for testing software and trying to learn how to program).
4. VM OS (created for experimenting with Virtual Machines and trying things out on a FreeNAS VM instead of my actual FreeNAS server).
The goal is to be able to backup each OS independently of the other. This way I will be able to roll back any OS on the machine to a certain point without also rolling back all the other OS's. I would like this to be administered via the FreeNAS server, but I don't understand RSync at the moment and do not even know if RSync is appropriate to my situstaion.
I have tried backing up each OS using a trial version of Acronis. These images are stored locally and then copied manually to the FreeNAS server as Acronis can't communicate with the FreeNAS server when it reboots into it's own start-up program.
This has failed. It results in being able to restore any particular OS of my choice, but renders all the other OS's non-bootable (but they do appear in the Windows boot manager).
All I can do with any success is take one image of the entire system and restore from that. This works fine but the OS's can no longer be rolled back indepenently. This is really important to me.
Also this approach involves having to remember to make backups and to copy the images across to the FreeNAS server. I would prefer something entirely automated because I'm a bit forgetful/senile these days.
There is also a further complication caused by the DAW OS. When recording multiple tracks and simultaneously playing back multiple samples, HDD activity can become quite intensive. So it is best if the DAW OS is backed up manually when I ask for it and not automatically. This will ensure there are no audio glitches or drop outs caused by a backup going on in the background when making music.
I have no idea how to approach this problem or if it is even possible to backup a multiboot system in this way.
If anyone has some advice I would be very pleased to hear it as I have hit a dead end here.
Thank you to anyone who takes the time to respond.
UncleFester
UncleFester
