Glenn Buckholz
- Apr 3, 2015
I am currently trying to leverage the internal ACME plugin to secure the UI and rest endpoints with SSL. I am doing the following:
1. Create and ACME authenticator with my Route53 information
2. Creating a CSR
3. Try to approve CSR with ACME
When we get to step 3 I get an exception:
This seems like it would be easy to fix. Has anyone else encountered or fixed this?
2. Creating a CSR
Error: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run await self.future File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 385, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/crypto.py", line 1279, in do_create job, data File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 965, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/crypto.py", line 1325, in __create_acme_certificate final_order = self.acme_issue_certificate(job, 25, data, csr_data) File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/crypto.py", line 956, in acme_issue_certificate normalised_san = ':'.join(self.middleware.call_sync('cryptokey.normalize_san', [domain])) TypeError: sequence item 0: expected str instance, list found
