Hello everyone,
I have installed freenas 11.3 U2 multiple times trying to fix this issue and keep getting the following error message when I try to enable vlans. I have 2 nics and one is being used as my management nic.
When I try to enable a vlan and save the changes, I get the following error message
I have tried forcing the nic to non-dhcp and not specifying a ip but I run into the following error message
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
io_thread=False)
File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1084, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/network.py", line 664, in commit
await self.__check_dhcp_or_aliases()
File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/network.py", line 593, in __check_dhcp_or_aliases
'At least one interface configured with either IPv4 DHCP, IPv6 auto or a static IP'
middlewared.service_exception.CallError: [EFAULT] At least one interface configured with either IPv4 DHCP, IPv6 auto or a static IP is required.
Switchport shows as
interface 0/22
description 'FREENAS'
switchport mode trunk
switchport trunk native vlan 210
switchport trunk allowed vlan 1,210,220,230,240,250
ip mtu 1500
I have tried with and without native vlan and my pfsense firewall is acting as the dhcp server. All other devices work except for freenas.
Any assistance would be greatly appreciated.
Thanks
io_thread=False)
Switchport shows as
interface 0/22
ip mtu 1500
Thanks
