Afternoon all,
Late last week my freenas-boot USB running Corral died. I am trying to recover the Docker data that I had on that install to save starting again.
Really - the only Docker I care about is the Plex database. If I can access that I can import into a FN 11 Plugin to recover Plex.
So...any ideas how I can mount/expand the storage.img file from the FN Corral install to view the docker data?
I have rebuilt FreeNAS to FN 11 and have imported the pool that the Docker was installed on - so have full access to all the original data on the disks. (Just still trying to recover my media! :|)
I found this in this thread: https://forums.freenas.org/index.php?threads/rancheros.53769/
Is anyone able to elaborate to help me view the files in the .img? Is this even possible?
Would creating that script on FN11 and running it (with a little editing) work?
Thanks
root@box:/etc/rc.d# cat automount #!/bin/sh echo "automount ..."; rm -rf /var/lib/docker mkdir /var/lib/docker mkdir /host mount -t 9p -o version=9p2000.L -o trans=virtio -o cache=mmap -o msize=512000 docker /var/lib/docker mount -t 9p -o version=9p2000.L -o trans=virtio -o cache=mmap -o msize=512000 mnt /host if [ ! -f /var/lib/docker/storage.img ]; then /usr/local/bin/truncate -s 1T /var/lib/docker/storage.img mkfs.ext4 /var/lib/docker/storage.img fi mount -o loop /var/lib/docker/storage.img /var/lib/docker echo "automount over." root@box:/etc/rc.d#
Thanks
