9.3 to 11 ??
Matt Lock
Hi All, so I think it's about I upgraded and updated my jail templates, etc. Can I go straight to 11 or should I hit 9.10 first?
Thanks!
You should be able to switch directly to 11.
Jailer
Not strong, but bad
Save a copy of your config just in case things don't go well.
Matt Lock
Upgrade straight to 11 went perfectly! All jails working great. I love this solution, thank you for all your hard work.
The only error I got was afpd: No Suitable network config for TCP socket. I needed to re-enable the interface binding in the AFP service. All good now.
ParkyZA
Hi
I just want to get clarity on upgrade. If I use GUI way, do I just point to where ISO is and upgrade from 9.10 to 11 will continue? I have already done config backup etc.
thanks
No, you switch trains to 11-Stable and run the updater.
pjc
Thanks for the heads up, we'll get that link updated for U1.
In the mean time could you point us to the corrected link? I couldn't even find a copy of that FAQ on archive.org.
I'm guessing I should probably update my 9.3 to the latest 9.3-STABLE before switching trains to 11?
