9.3 sending alerts for unreadable drives
godofdew11
Hey guys,
Running 9.3 on an intel i3-2100/MSI-H67MS-e43, 16 gigs ram, 5xHitachi desksta 2TB raidz
I am getting emails stating errors are climbing on 2 drives, and most recently that they are unreadable.
When I log into GUI i have red alert light on right side stating 4 critical alerts two drives unreadable 2 drives offline (same 2)
When I go to Storage-Volumes-view volumes-volume status it shows all 5 drives with 0 errors and all online.
Do i have dead drives? Please bear with me I am not terribly experianced with freenas
Thanks,
Don
Sakuru
Please post the output of the "zpool status" command.
Bidule0hm
Server Electronics Sorcerer
And the output smartctl -a /dev/adaX for each drive between code tags please.
godofdew11
zpool status
scan: scrub repaired 0 in 10h57m with 0 errors on Sun Feb 28 10:57:46 2016
NAME STATE READ WRITE CKSUM
Donsnetworkstorage ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gpt/ad0 ONLINE 0 0 0
gpt/ad1 ONLINE 0 0 0
gpt/ad2 ONLINE 0 0 0
gpt/ad3 ONLINE 0 0 0
gpt/ad4 ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0h1m with 0 errors on Thu Feb 25 03:46:26 2016
freenas-boot ONLINE 0 0 0
gptid/73a1e3b8-089a-11e5-9d1f-6c626d3a4e60 ONLINE 0 0 0
[root@freenas ~]#
when i run the last command (smart test?) it scrolls through and leaves a bunch of information i cant get to. but 2 of the discks come back with different info at the end then the others, the ones showing error in gui
ada0
Short self-test routine
Extended self-test routine
recommended polling time: ( 380) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 136 136 054 Pre-fail Offline - 95
3 Spin_Up_Time 0x0007 141 141 024 Pre-fail Always - 395 (Average 382)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 101
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 146 146 020 Pre-fail Offline - 29
9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 41342
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 101
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 306
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 306
194 Temperature_Celsius 0x0002 214 214 000 Old_age Always - 28 (Min/Max 17/42)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada1
Error 29 occurred at disk power-on lifetime: 38298 hours (1595 days + 18 hours)
ER ST SC SN CL CH DH
84 51 8d 0d 03 1e 06 Error: ICRC, ABRT 141 sectors at LBA = 0x061e030d = 102630157
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 00 ac ee 02 1e 40 00 3d+18:56:54.089 READ DMA EXT
25 00 ab 43 02 1e 40 00 3d+18:56:54.088 READ DMA EXT
25 00 ac 97 01 1e 40 00 3d+18:56:54.087 READ DMA EXT
25 00 ab ec 00 1e 40 00 3d+18:56:54.086 READ DMA EXT
25 00 ab 40 00 1e 40 00 3d+18:56:54.085 READ DMA EXT
Error 28 occurred at disk power-on lifetime: 38297 hours (1595 days + 17 hours)
84 51 4c f4 83 59 03 Error: ICRC, ABRT 76 sectors at LBA = 0x035983f4 = 56198132
25 00 ab 95 83 59 40 00 3d+18:09:04.153 READ DMA EXT
25 00 ab e9 82 59 40 00 3d+18:09:04.152 READ DMA EXT
25 00 ac 3d 82 59 40 00 3d+18:09:04.151 READ DMA EXT
25 00 ab 92 81 59 40 00 3d+18:09:04.150 READ DMA EXT
25 00 ac e6 80 59 40 00 3d+18:09:04.149 READ DMA EXT
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada2
recommended polling time: ( 375) minutes.
2 Throughput_Performance 0x0005 135 135 054 Pre-fail Offline - 98
3 Spin_Up_Time 0x0007 139 139 024 Pre-fail Always - 404 (Average 387)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 105
9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 41346
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 105
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 304
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 304
194 Temperature_Celsius 0x0002 214 214 000 Old_age Always - 28 (Min/Max 17/43)
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada3
recommended polling time: ( 394) minutes.
3 Spin_Up_Time 0x0007 141 141 024 Pre-fail Always - 395 (Average 381)
8 Seek_Time_Performance 0x0005 148 148 020 Pre-fail Offline - 28
9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 41347
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 301
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 301
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ada4
ATA Error Count: 1
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 40909 hours (1704 days + 13 hours)
40 51 53 65 f6 1e 05 Error: UNC 83 sectors at LBA = 0x051ef665 = 85915237
25 00 ab 0d f6 1e 40 00 3d+12:59:25.418 READ DMA EXT
25 00 ac 61 f5 1e 40 00 3d+12:59:25.418 READ DMA EXT
25 00 ab b6 f4 1e 40 00 3d+12:59:25.417 READ DMA EXT
25 00 ab 0a f4 1e 40 00 3d+12:59:25.416 READ DMA EXT
25 00 ac 5e f3 1e 40 00 3d+12:59:25.375 READ DMA EXT
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Hope that is what you guys are looking for.
Thanks for the help!
Don
Sakuru
If you use something like putty to SSH into your FreeNAS box you will be able to scroll back. Also, it can be useful to save the output to a text file. "smartctl -a /dev/adaX > adaX.txt".
It makes your post more readable if you use Code tags for text dumps like you get from smartctl. See the attached picture.
Bidule0hm
Waow, 41 kh and no SMART test ever executed on those drives?
Please do a long SMART test on each drive (smartctl -t long /dev/adaX) and then repost the output of smartctl -a.
gpsguy
Active Member
^^ I would have replied earlier with a similar message, but some replies are difficult to type on my phone.
joeschmuck
Old Man
First you need to run a SMART Long Test as @Bidule0hm stated on each drive and then once those are complete, report the drive data. You also need to establish routine SMART testing to be accomplished. I prefer a daily short test and a once a week long test on all my drives. It would be nice to post exactly what the emails said, that should identify the hard drives (I hope).
Try my troubleshooting guide here, it will step you though everything you need to do to identify the problem:
https://forums.freenas.org/index.ph...leshooting-guide-basic-common-failures.41026/
All the instructions to identify your problems should be clear, if not, ask.
