In setting up a new 9.3 install with 4x2TB HD, volume manager does not offer a RAIDZ2 config but only a 2x2 mirror/stripe. I checked the docs & this seems contrary to what they say and prior 9.3 setups have offered Z2 pools. Is there anyhting I should check/try? I do note that this is a very minimal system that is below spec (old Atom w/ 2GB RAM max) but it has run 9.2 well in its role in the past and seems fine on 9.3, except the pool config is not as expected. Any info/ideas appreciated.
