I set up a FreeNAS server last summer and I made a few non-optimal choices due to financial constriants that I'd like to correct.
My current config is FreeNAS 9.2 running off a USB stick, with 4x 3TB WD Red drives configured as RAIDZ1. Two Plex instances serving a maximum of three streams HD streams between them, and an owncloud instance with one user and half a dozen client systems (two of which are mounting davfs not synchronizing). 16GB ECC RAM, with ample CPU cycles to spare (Xeon E3-1230v2). Used space is a little more than 50% (4.4GB). That's where I'm at now.
My intent is to add a two more 3TB disks and reconfigure as a RAIDZ2 to add capacity and redundancy, and at the same time, upgrade to 9.3. I understand I'll have to rebuild the zfs pool to accomplish this, which means backing up my existing data (twice), doing the install, and restoring my zfs datasets.
I have a technical background, but I'm reasonably new to zfs. I also have somewhat limited resources - I don't have a suitable tape subsystem, but I do have several external USB 3.0 drives (2x 4TB and 1x 3TB).
95%+ of my data isn't *critical*, it's replaceable, but the rest isn't.
How would you go about doing this upgrade?
ETA: I know I'm going to take some performance hit going from RAIDZ1 to RAIDZ2. I ok with this, redundancy is far, far more important to me.
