Shadowgundam2725
- Mar 15, 2016
OS: FreeNAS-9.3-STABLE-201602031011
Mobo: Asus P5B-Deluxe
Processor: Intel Quad2Core Q6600 2.4 GHz
RAM: 4GB DDR2 Pc800 (will be ordering more ram but have to wait for the moment)
HDD: 2TB SSHD Seagate drive x2
I was running 9.2.1.5 as a local plex server, when a power surge came through and rebooted the system. After the reboot I could not access plugins and researched it on forums. The conclusion I kept finding was to reinstall the OS and start over. I had a friend help me with the install and he suggested I go ahead and upgrade to 9.3 stable since I was starting from scratch essentially. He has more experience with FreeNAS than I do, so I thought this was a good suggestion. After installing 9.3 everything was working ok, until we tried to import the volume from the old OS.
The wizard saw the volume and said it would import it, but once the wizard was done the volume was not there. His said this was ok, we just needed to upgrade the zpool. After upgrading the zpool we exported the volume from the shell and tried to import it again from the GUI. The Gui sees the volume and tries to import it and refreshes the screen. Again there is still nothing showing in volumes. At this point he had to leave and I am on my own for now. I have been reading forums for three days now trying to solve this, I see 8GB is the recommend RAM and plan to upgrade but cannot at this exact moment as the power surge took out my router and modem (these were on a different power-strip) and I just replaced those, so money is tight at the moment. I see a lot of post similar to mine but most are resolved off site or have things I have tried above work, but not for me.
When I run zpool import Media get:
[root@freenas ~]# zpool import Media
cannot mount '/Media/.system': failed to create mountpoint
cannot mount '/Media/.system/cores': failed to create mountpoint
cannot mount '/Media/.system/samba4': failed to create mountpoint
cannot mount '/Media/.system/syslog-901a1ff993dd48fd941728573b836c3f': failed to create mountpoint
cannot mount '/Media/Movies': failed to create mountpoint
cannot mount '/Media/TVshows': failed to create mountpoint
cannot mount '/Media/pluginjails': failed to create mountpoint
cannot mount '/Media/pluginjails/.warden-template-pluginjail-9.2-x64': failed to create mountpoint
cannot mount '/Media/pluginjails/plexmediaserver_2': failed to create mountpoint
afterwards when I run zpool status I get:
[root@freenas ~]# zpool status
pool: Media
state: ONLINE
scan: scrub repaired 0 in 4h14m with 0 errors on Sun Mar 13 05:15:00 2016
NAME STATE READ WRITE CKSUM
Media ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/676b26ad-c3eb-11e5-9ca8-0018f3844dcc ONLINE 0 0 0
gptid/67aaeb5b-c3eb-11e5-9ca8-0018f3844dcc ONLINE 0 0 0
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: none requested
freenas-boot ONLINE 0 0 0
gptid/5820669c-eb15-11e5-b06e-0018f3844dcc ONLINE 0 0 0
Thank you for any help you can offer this is my first post, also please shoot it to me straight I am big boy and can handle it.
pool: Media
state: ONLINE
Media ONLINE 0 0 0
pool: freenas-boot
state: ONLINE
