9.2.1.8 - How to add global options to afp.conf?
kjp4756
I need to disable zeroconf on afp. How can I do this on FreeNAS 9.2.1.8? On 9.3 there is a way to add global options.
I've tried editing /conf/base/etc/local/afp.conf but that didn't do much. I also see a /conf/base/etc/local/afp.conf.dist. Is that the file I should edit?
Thanks.
Editing files isn't going to go well because the OS creates the files per the config and such. So anything you try to do yourself is going to get overwritten by the OS at some point.
Unfortunately the only good answer I have for you is wait for 9.3. :/
kjp4756
I figured it out. This will work for for me until 9.3 is out.
The file I had to edit was /usr/local/www/nas/generate_afpd.conf
I had to add cf_contents.append("\tzeroconf = no\n") after cf_contents.append("\tmimic model = RackMac\n")
Keep in mind if you reboot you'll have to reapply your changes. That's why I said that editing the files won't work out so well....
kjp4756
The changes I made to generate_afp_conf.py are sticking after a reboot. When I originally tried changing afp.conf those changes never stuck.
That's expected (but unsupported) behavior.
I believe 9.3 adds integrity checks to system files, so this kind of method may not work much longer.
You must have made the boot device writable and changed the settings.
As for 9.3 I think he's okay because the setting is in the GUI already. ;)
BUT, editing the files in 9.3 is gonna be hilarious to do. I can't wait to see all the crybabies that find out the hard way that editing files will end in tears and other "less than satisfactory" situations.
