8 drive to M1050 + 2 drive from mobo SATA to form 10 disk Raidz2?
Multiplexer
I have created a 10 drive FreeNAS raidz2 with 8 disk connected to M1015 and 2 disk connected to the motherboard. My question will mixing SATA connection cause problem?
mobo: Supermicro X10SDV-4C-TLN2F
HBA: M1015 flashed to LSI 9240-8i IT
RAM: 32GB
disk: Hitachi 8TB
While we are on the subject of my build, will 32GB of RAM be sufficient if I only use it as a file server?
EDIT: I meant to say IBM M1015 flashed to LSI 9240-8i IT
Stux
I have created a 10 drive FreeNAS raidz2 with 8 disk connected to M1050 and 2 disk connected to the motherboard. My question will mixing SATA connection cause problem?
No. Not sure what you mean by M1050, but I'm assuming you mean an LSI HBA of some sort.
HBA: M1050 flashed to LSI 9240-8i IT
RAM: 32GB
disk: Hitachi 8TB
Most likely. If after a while, you're not happy with your ARC hit ratio, then consider increasing RAM. X10SDV supports 128GB.
Multiplexer
Thanks,
I just use the basic FreeNAS feature, i.e. backup and file share for 1 user, "me". The hit ratio is currently 31%. Is this acceptable? I have order more RAM, but if the current 32GB of RAM with a hit ratio of 31% is acceptable then I prefer to use the extra RAM for other purposes.
Stux
If you're happy, its fine.
Chris Moore
I think the SAS controller is better, but there should be no problem with mixed connectivity to the drives.
