B
Bohs Hansen
Guest
I've just setup my new box with FreeNAS 8 and 4x Seagate V35.5 2TB drives, they are 4kb sectors. Didn't have to do anything, setup managed it fine.
# write test
dd if=/dev/zero of=/CHANGE/THIS/PATH/zerofile.000 bs=1m count=4000
# read test
dd if=/CHANGE/THIS/PATH/zerofile.000 of=/dev/null bs=1m
Warning: do not make mistakes with this command. Change the /CHANGE/THIS/PATH string to where your primary data array is mounted.
#zdb -U /data/zfs/zpool.cache | grep ashift
100 MB/s for samba is doable, you just need a fast system.
my system (dual gigabit nic) can sustain 200MB/s in and out at the same time.
The disks will work, but the question is about the performance, read/write speed and the allign
And maybe the NIC, because i get 30Mb/s on the same machine using FreeNAS...
Please let us know what is your system.... At this moment I have installed freenas 8 in a Phenon x6 1090T and 8Gb RAM, NIC Gigabit (Realtek 8111E) and only can get 30 MB/s under samba. I think my problem is the NIC....
Thanx in advance
i have 'Large RW support', 'Send files with sendfile(2)' and 'Enable AIO' checked in my cifs config page. try enabling those and see what happens.
Connect the NAS directly to the PC, set up your IP manually (192.168.1.1 , 192.168.1.2 for example) and test the speed. So you will be sure the router is not the bottleneck. Maybe it sounds stupit, because on the box is text like "1Gbit router!", but i don't belive to those SOHO solutions. ( Mikrotik powah! :p )
can you run 'top' when you make a large transfer of a single file? which processes are at the top, how much cpu are the taking....
let me know what you see.
