When installing TrueNAS SCALE 23.10.2 for the initial time (I have never used TrueNAS before, I was not thinking (or misread) and selected both hard disks (mirrored) and the ssd as bootable.
Now I cannot create any pools because there are no disks available.
I would like to have only the ssd as bootable.
I saw in an old posts this is possible to detach disks from a pool, but in this latest version there is only replace (which is not useful for this particular scenario)
I don't mind using the command line (there used to be a zpool remove command but it wasn't recognised), but prefer there was something in the UI to make a disk unbootable.
Appreciate any ideas you may have.
regards,
Simon
regards,
Simon
