boy2litle
- Aug 16, 2018
Hello people!
I've spend my last 2 week looking for a NAS. I've started looking at an used diskless Drobo NAS (4bay or 5bay) and I've endup with Synology and Qnap.
I love the ease of use of a Drobo, I love how stable it is a Synology, I love the features of Qnap and I hate the amount of money that you have to spend to get an used one which does have just 4 of 5 bay.
I already have the following 7 internal HDD which I plan to use in my future DIY NAS:
- 1 x 80 GB Western Digital - WD800 - https://bit.ly/2nGdWBE
- 1 x 250 GB Seagate - ST3250820AS - https://bit.ly/2Mn4fa3
- 1 x 500 GB Western Digital - WD5000AADS - https://bit.ly/2MVzrsX
- 1 x 320 GB Western Digital - WD3200AAKS - https://bit.ly/2Mvrm1n
- 2 x 2000 GB Seagate ST2000DM001 - https://cnet.co/2L4bApy
- 1 x 3000 GB HGST - https://bit.ly/2w6rQAM
Also it's on it's way an external 8TB Hard Drive (Seagate Expansion 8TB Desktop External Hard Drive USB 3.0 (STEB8000100)) - https://bit.ly/2KYFcnS
I'm planing to buy a SSD for cache, but I will need your help to know what will suit my actual and future needs.
The Internal hard drives have data on t em and the plan is to transfer them on the external 8TB HDD and after that to use them in my FreeNAS.
Specs Future FreeNAS
As you notice in the title, my budget is very tight, around 200 euro. And I want to build a FreeNAS where I will be able to have 8-10 HDD bay available (considering the ones for the optical drive, which I will convert them into HDD bay). Also is very important for me to have an motherboard with Gigabit LAN port, ECC memory compatible, enough SATA ports (8 or 10), and which cat take at least 32GB DDR3 ECC memory or more.
I'm planing for the moment to use as a storage space for my work, but to use it as a Home Media Server and if possible as a web server and streaming server as well (as you can do with Synology or Qnap).
I'm planing either to buy a used case with multiple 3.5 bays and a used PC from which I will re-purpose the parts, or to buy used parts (but if I will do so, I might end-up with some compatibility issues). Me and my wife will be the only two persons that will use this NAS, using either our laptops, tables or smartphones, and pretty often we might use it in the same time.
After lots or researches I'm still not sure what parts I should use and consider fine for my build because I don't know what parts are fine enough for my actual almost 8TB of total storage and for a future 32TB or 64 TB of space, once that I will start to replace my drives one by one.
I had in mind an some prebuild PCs:
- HP Z200 Workstation PC Intel Core i5-650
- HP Compaq 6200 Pro Desktop PC i3 2100
- Dell Precision 490 workstation dual Xeon 3.2Ghz
- Dell Precision T3500 PC Xeon X5670 hex core
- Dell Precision T3500 Workstation Xeon W3520 CPU @ 2.66GHz
- HP Z400 Intel Xeon Quad Core W3530 2.80GHz
, but the motherboard does not support ECC memory or I don't know if the CPU it will be powerful enough for a future 32TB storage and for all the task that I will trough at it.
Because of that I might consider to buy the parts:
I found the following CPUs:
- INTEL XEON E5-2609 2.4GHZ 10MB 4-CORE SANDYBRIDGE-EP SR0LA LGA2011 80W TDP CPU
- Intel Xeon E5-1603-V1 (SR0L9) 2.80GHz Quad Core LGA2011 CPU Processor
- Intel Xeon E5 2603 1.8GHz SR0LB Server CPU Socket LGA2011 4 Core Sandy Bridge
- Intel Xeon E5-2630L Six 6 Core Processor 2.00GHz 2.5GHz Turbo LGA2011
- Intel Xeon X5680 3.33GHz 1366 CPU
- Intel Xeon E5 2640 SR0KR | 2.50GHz Six Core LGA2011 CPU
- Apple Intel i5-2400S 2.5ghz Processor Skt H2 LGA1155
- Intel i5-2500s 2.7GHz SR009 SKT H2 LGA1155 iMac
- Intel Core i7 - 3820 SR0LD 2nd Generation Processor CPU / 4 Cores / LGA 2011
but I don't know which one is powerfull enough for my FreeNAS. Feel free to recommend my any other cheap and very powerful CPU suitable for my NAS.
I have found the following motherboards (open to any other ECC ready motherboard suggestions):
- X58 LGA 1366 DDR3 16GB Support ECC RAM Lot LN
- Intel Motherboard X79 LGA 2011 - (M) ATX DDR3 ECC USB 3
- X58 Mainboard LGA 1366 DDR3 16GB Support ECC RAM (even if supports up to 16GB memory)
- Power supply
What's the most efficient 80+ case that you can recommend me, which will be fine for now but for future as well? Any good price recommendations?
I'm planing to use either RAID 6 on my NAS for safety, because I will be able to loose 2 HDD and still to have my data save . Will I need an RAID PCI card? Can you recommend me one?
Can you recommend me something better than RAID 6?
What OS should help me better with the above mentions features?
I really need your hel to build this one to stay in the budget and to be able to build this NAS with the above features.
Thank you in advance for your time and for your help!
- Power supply
