silversword
- Nov 9, 2017
So I'm certain this is another "hardware not suited for a file server" (Dell inspiron 580), this is just testing FreeNAS with some existing hardware before blowing 1-2K on dedicated hardware.
During the troubleshooting extremely slow installation (I did 6 failed installs because I didn't wait long enough) because I thought the installer was crashing, it was dropping out of the GUI installer after clicking ok on one of the data entries (password etc).
The only reason I discovered it was a hardware issue was that I finally went to bed after starting a new install, and found it finished in the AM.
I think the main issue to fix would be to reduce the initialization timeout period for any SD/MMC devices during both installs and boots.
I believe the slowdown is the 4+ card reader that I can't disable in BIOS, and doesn't have a card in it. Here's the errors that are on the screen during the long wait periods
That one screen was 15mins if initialization and waiting.
