Decided to switch my home server over to FreeNAS but I can't get the installer to work. I had to change around some Bios settings to get it to stop hanging immediately as it tried to boot. After finally get that worked out I thought everything was going to work because I finally got to the ascii shark splash screen. This is as far as it manages to get. Once I tell it to start, or just let the timer go, a lot of lines of console output (or whatever it is) are printed to the screen for quite a while until it reaches a point where it just reboots. From there this continues to loop until I just turned it off.
I checked for hardware compatibility and as far as I could tell that shouldn't be a problem. I have tried remaking the installation media using both rufus and Win32 Disk Imager, using the checksum to make sure my download was fine, and using 2 different USB drives.
System Specs:
System Specs:
Motherboard:
Asus Z10PE-D16 WS
CPU:
2 x Intel Xeon E5-2609 V4
RAM:
8 x 8 GB Kingston KVR21R15S4/8
RAID Hardware:
LSI Logic SAS9260-8I SGL
Intel RAID Twenty-four port Expander Card RES2SV240
Hard drives:
Samsung 950 PRO 512 GB
6 x 2 TB HDD
18 x 1 TB HDD
