Rusty!
- May 24, 2017
I thought I'd give 11.2 a try, and move some of my warden jails/plugins to iocage, for the most part it's gone well, but I cannot install the sabNZBd plugin, it fails with the error
and the more info option gives:
It's not the end of the world as the warden jail is all good, but I'd like to solve it and get rid of the deprecated stuff.
[priority,] message string
Error: concurrent.futures.process._RemoteTraceback:
File "/usr/local/lib/python3.6/concurrent/futures/process.py", line 175, in _process_worker
r = call_item.fn(*call_item.args, **call_item.kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 122, in main_worker
res = loop.run_until_complete(coro)
File "/usr/local/lib/python3.6/asyncio/base_events.py", line 468, in run_until_complete
return future.result()
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 82, in _run
return await self._call(f'{service_name}.{method}', serviceobj, methodobj, params=args, job=job)
File "/usr/local/lib/python3.6/site-packages/middlewared/worker.py", line 75, in _call
return methodobj(*params)
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 662, in nf
return f(*args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/jail.py", line 238, in fetch
iocage.fetch(**options)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/iocage.py", line 909, in fetch
props, accept_license=accept, official=official)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 689, in fetch_plugin_index
props, 0, accept_license)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 115, in fetch_plugin
self.__fetch_plugin_inform__(conf, num, plugins, accept_license)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_plugin.py", line 215, in __fetch_plugin_inform__
silent=self.silent)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_common.py", line 82, in logit
_callback({"level": level, "message": msg}, exit_on_error)
File "/usr/local/lib/python3.6/site-packages/iocage/lib/ioc_common.py", line 55, in callback
log.log(15, message)
File "/usr/local/lib/python3.6/logging/__init__.py", line 1372, in log
self._log(level, msg, args, **kwargs)
File "/usr/local/lib/python3.6/logging/__init__.py", line 1442, in _log
self.handle(record)
File "/usr/local/lib/python3.6/logging/__init__.py", line 1452, in handle
self.callHandlers(record)
File "/usr/local/lib/python3.6/logging/__init__.py", line 1514, in callHandlers
hdlr.handle(record)
File "/usr/local/lib/python3.6/logging/__init__.py", line 863, in handle
self.emit(record)
File "/usr/local/lib/freenasOS/__init__.py", line 152, in emit
_msg)
TypeError: [priority,] message string
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 332, in run
await self.future
File "/usr/local/lib/python3.6/asyncio/coroutines.py", line 129, in throw
return self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.6/site-packages/middlewared/job.py", line 356, in __run_body
rv = await self.middleware._call_worker(self.serviceobj, self.method_name, *self.args, job={'id': self.id})
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 977, in _call_worker
job,
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 908, in run_in_proc
return await self.run_in_executor(self.__procpool, method, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 902, in run_in_executor
TypeError: [priority,] message stringIt's not the end of the world as the warden jail is all good, but I'd like to solve it and get rid of the deprecated stuff.
