11.2 Dell R510 kernel error
timbit123
I don't know if i'm the only one, I'm getting Kernel panic from a usb drive with installation on it or if I upgrade my current environnement. Right now i'm running 11.2 Beta 2 and since this version I could not upgrade to beta3, rc1 or current release without having the boot error.
It display
Fatal trap 12: page fault while in kernel mode
cpuid =0; apic id = 10
fault virtual address = 0x6108
here is a video of the boot
https://www.youtube.com/watch?v=Ui4zu4AfAdM
I don't know what other information would be needed for support, let me know.
Thank you,
Tim
D
dlavigne
Guest
Does installing fresh on a new USB stick resolve the issue? That error most often indicates a dying boot device.
timbit123
No, I had the same error on multiple usb stick and I couldn't boot the installation. I also tried using the idrac and mount the iso to install it on the server and still getting the fatal trap in any method.
D
dlavigne
Guest
Does it boot/install OK using 11.1? If so, please create a debug and attach it to a bug that you report at bugs.freenas.org.
