Enchanted14
 - Oct 4, 2014
I am trying to upgrade an existing install of FreeNAS 9.3 to a USB mirror. I cannot do this upgrade via the GUI because the system became unbootable with a checksum failure error thus my attempt to upgrade via USB installer.
The error I am getting now I think it is telling me that my da2 drive is toast but am not sure. Error below:
(da2:umass-sim2:2:0:0): WRITE (10). CDB: 2a 00 01 58 60 d2 00 00 22 00
(da2:umass-sim2:2:0:0): CAM status: Check Condition
(da2:umass-sim2:2:0:0): SCSI sense: NOT READY asc:3a,0 (Medium not present)
(da2:umass-sim2:2:0:0): Error 6, Unretryable error
Fatal trap 12: page fault whil in kernel mode
cpuid = 3; apic id = 06
fault virtual address = 0x298
fault code = supervisor read data, page not present
instruction pointer = 0x20:0xffffffff803bb443
stack pointer = 0x28:0xfffffe048dae3a40
frame pointer = 0x28:0xfffffe048dae3a70
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags = interrupt enabled, resome, IOPL = 0
current process = 5 (solthread 0xffffffff)
[ thread pid 5 tid 100171 ]
Stopped at spa_async_remove+0x13: movl 0x298(%rsi),%r10d
db>
Is it safe to shutdown the machine at this point?
Should I remove the da2 drive and attempt to repair/install to a single USB stick?
Any and all help appreciated.
db>
