11.2-beta3 and drive issues
micheal0001
I have a clean install of 11.2-beta3 and zfs setup a clean install with a new usb drive. After 2 clean installs to make sure it wasn't an installation issue my drives aren't listed in storage. However when when go to shell and run camcontrol devlist the drives are listed. How do I get them to show up in storage so that I can import my zfs and get to the data? Thanks in advance for any input that would point me in the right direction.
kdragon75
I'm sorry your having issues with a clean install. Can you please provide the output of lspci and camcontrol list in code tags?
micheal0001
Thank you for helping me.
lspci output
root@freenas[~]# lspci
00:00.0 Host bridge: Intel Corporation 82Q35 Express DRAM Controller (rev 02)
00:01.0 PCI bridge: Intel Corporation 82Q35 Express PCI Express Root Port (rev 02)
00:02.0 VGA compatible controller: Intel Corporation 82Q35 Express Integrated Graphics Controller (rev 02)
00:03.0 Communication controller: Intel Corporation 82Q35 Express MEI Controller (rev 02)
00:03.0 Communication controller: Intel Corporation 82Q35 Express PT IDER Controller (rev 02)
00:03.0 Communication controller: Intel Corporation 82Q35 Express Serial KT Controller (rev 02)
00:19.0 Ethernet controller: Intel Corporation 82566DM-2 Gigabit Network Connection (rev 02)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02)
00:1a.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02)
00:1d.0 USB controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92)
00:1f.0 ISA bridge: Intel Corporation 82801IO (ICH9DO) LPC Interface Controller (rev 02)
00:1f.0 ISA bridge: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)
00:1f.0 ISA bridge: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
camcontrol devlist
root@freenas[~]# camcontrol devlist
<TOSHIBA DT01ACA100 MS2OA7C0>	  at scbus2 target 0 lun 0 (ada0,pass0)
<TOSHIBA DT01ACA100 MS2OA7C0>	  at scbus3 target 0 lun 0 (ada1,pass1)
<TOSHIBA DT01ACA100 MS2OA7C0>	  at scbus4 target 0 lun 0 (ada2,pass2)
<TOSHIBA DT01ACA100 MS2OA7C0>	  at scbus5 target 0 lun 0 (ada3,pass3)
<PNY USB 2.0 FD 1100>			  at scbus8 target 0 lun 0 (pass4,da0)
gpart show
root@freenas[~]# gpart show
=>	  40  31405744  da0  GPT  (15G)
		40	  1024	1  freebsd-boot  (512K)
	  1064  31404720	2  freebsd-zfs  (15G)
=>		40  1953525088  ada0  GPT  (932G)
		  40		  88		- free -  (44K)
		 128	 4194304	 1  freebsd-swap  (2.0G)
	 4194432  1949330696	 2  freebsd-zfs  (930G)
=>		40  1953525088  ada1  GPT  (932G)
=>		40  1953525088  ada2  GPT  (932G)
=>		40  1953525088  ada3  GPT  (932G)
After a reboot drives ada1 and ada3 showed up in storage/disks but disks ada0 and ada 2 are still not showing so I can't import my zfs volume.
kdragon75
I would suggest going back to 11.1U6 and see if that makes a difference. Is there an old pool on the drives that your trying to import? If so, what version did you have before?
micheal0001
I had it upgraded from 11.1-u6 to 11.2beta2 and iocage wasn't working and I couldn't properly install plugins. So I chose to do a clean install of 11.2beta3 to this result. I do have a zfs pool I wish to import. Thank you for the suggestion I will go ahead and do just that and do a fresh install of 11.1-u6.
RaphM123
Hi, I upgraded to 11.2-beta and seem to have exactly the same problems:
* Boot takes unusually long, most notably there also is a Midlewared failed to start within 4 minutes. message (along others)
* The "List Drives" UI only displays 3 of my 8 drives
* Command line shows all drives (lspci output/camcontrol devlist etc.)
I even was able to import my pools using the command line (zpool import -f), and they now show up as online and OK using zpool list.
Still they are not visible on the UI, so I cannot, for example, create a Fileshare that provides my pools (dropdown is empty).
Can provide further data as soon as I am home.
kdragon75
RaphM123
Thanks, import/export via command line and then importing from GUI worked - I am now able to see the pools via "Storage -> Pools" and in seleciton boxes like "Path" for SMB Fileshares. Also creating and accessing the Fileshares works, so on a technical level everything seems functional now.
However, I still have a similar problem with the individual disks - "Storage -> Disks" shows only subset (3 of 8) of my physical disks.
As already mentioned, on a technical level all disks are operational, it again seems to be a GUI issue only.
For example this hinders me me from creating scheduled S.M.A.R.T. tests, since the dropdown will not show the remaining 5 disks.
kdragon75
Yeah That's an issue. You should file a bug report.
RaphM123
It seems that my problem was caused the slow USB Sticks I used as boot devices - I changed to a mirrored SSD setup for boot and no longer get the Midlewared failed to start within 4 minutes. upon startup and the device list is initialized correctly.
This may have solved it for me, but I am still posting here to make you aware of a potential problem - beginning with the 11.2Betas very slow boot devices seem to have some problems with initializing the data for the GUI correctly (as mentioned, via command line everything still worked) when running into the Midlewared failed to start error upon boot.
