11.2-BETA2 smartd failed to start - smartd.conf missing
Elliot Dierksen
Neophyte Sage
djseto
Member
I just upgraded to 11.2 U1 and I have this issue. Missing smartd.conf and there is no ix-smartd
Not-very-passive-but-aggressive
This should be fixed in -U2.
keson
Junior Member
I have just installed fresh new 11.2.U3 on HP micro server G7 and this error is there from a very beginning.
root: /etc/rc: WARNING: /usr/local/etc/smartd.conf is not readable.
guermantes
Member
Same here (almost).
Since fresh installing 11.2-U3 and loading config file from 11.0-U4 I have never received SMART emails although the rest of the system emails are sucessfully sent. Changes made to Services -> SMART -> edit are reflected in /usr/local/etc/smartd.conf, but there is no /etc/ix.rc.d/ix-smartd file at all. I gather that's why no emails are being sent. Not sure if I could use the line on the previous page as a template because there are so many options and switches and stuff.
katena
Newbie
I'm very sorry to say but this is still an issue and sincerely it should not be after such long time. Just a beginner in FreeNas, don't crack my head (kidding) but it's a thing that need to be said.
Fresh install FreeNAS-11.3-U4.1.
Tested:
1 x Raid card(obviously in HBA mode): HPE Smart Array P822 (I know, everyone will say not compatible nor recommended hardware)
3 x HBA cards: HPE H240 HBA and 2 cards with LSI 9211-8i chipset (DELL PERC H310 and Fujistu D2607-A11) both flashed to latest IT firmware 20.00.04.00-IT.
Same frustrating result:
- no presence of /etc/ix.rc.d/ix_smartd file
- file /usr/local/etc/smartd.conf is empty
- smartd is not running
From CLI:
root@freenas[~]# camcontrol devlist
<ATA KINGSTON SA400S3 B1E2> at scbus1 target 8 lun 0 (pass0,da0)
<ATA Samsung SSD 860 4B6Q> at scbus1 target 9 lun 0 (pass1,da1)
<ATA Samsung SSD 860 4B6Q> at scbus1 target 10 lun 0 (pass2,da2)
<ATA Samsung SSD 860 3B6Q> at scbus1 target 11 lun 0 (pass3,da3)
<ATA Samsung SSD 860 3B6Q> at scbus1 target 12 lun 0 (pass4,da4)
<HP iLO Internal SD-CARD 2.10> at scbus4 target 0 lun 0 (pass5,da5)
root@freenas[~]# smartctl -a /dev/da0
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p11 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Phison Driven SSDs
Device Model: KINGSTON SA400S37120G
Serial Number: 50026B778355B86B
LU WWN Device Id: 5 0026b7 78355b86b
Firmware Version: SBFKB1E2
User Capacity: 120,034,123,776 bytes [120 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
ATA Version is: ACS-3 T13/2161-D revision 4
SATA Version is: SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Sep 7 13:57:23 2020 EEST
SMART support is: Enabled
Same result for all the other SSDs (excluding the SD card - disabled SMART for it in Storage -> Disks -> Edit -> Enable SMART checkbox -> Unchecked)
If I manually add DEVICESCAN -a to /usr/local/etc/smartd.conf and manually start smartd daemon in CLI, surprise, smart is working.
So maybe this "bug" could finally be solved?
Regards!
