11.1 U4 upgrade SMB won't start.
silverback
I am aware that SMB shares were broken in 11.1 U3. Read that it was fixed in U4, so I upgraded from 11.1 U1. SMB won't start along with the log messages about nmbd, winbind and a core dump. Testparm showed no errors. Anyone else still having problems with upgrading 11.1?
silverback
Hmmm, I thought my specs were in my signature.
FreeNAS-11.1 U4-STABLE-201606270534 (dd17351)
SUPERMICRO MBD-X9SCM-F-O LGA 1155 Intel C204 Micro ATX Intel Xeon E3 Server Motherboard
Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
32 GB KingstonKVR16E11/8I EEC RAM
Z2: 6-4TB Seagate ST4000VN000
IBM SERVERAID M1015 IT Mode
anodos
Sambassador
Please upload your smb4.conf file
silverback
Thanks for having a look.
[global]
	encrypt passwords = yes
	dns proxy = no
	strict locking = no
	oplocks = yes
	deadtime = 15
	max log size = 51200
	max open files = 942599
	logging = file
	load printers = no
	printing = bsd
	printcap name = /dev/null
	disable spoolss = yes
	getwd cache = yes
	guest account = nobody
	map to guest = Bad User
	obey pam restrictions = yes
	ntlm auth = no
	directory name cache size = 0
	kernel change notify = no
	ea support = yes
	store dos attributes = yes
	lm announce = yes
	hostname lookups = yes
	time server = yes
	acl allow execute always = true
	dos filemode = yes
	multicast dns register = yes
	domain logons = no
	local master = yes
	idmap config *: backend = tdb
	server role = standalone
	netbios name = FREENAS
	workgroup = WORKGROUP
	security = user
	create mask = 0666
	directory mask = 0777
	client ntlmv2 auth = yes
	dos charset = CP437
	unix charset = UTF-8
	log level = 1
[sas1]
	path = "/mnt/sas1"
	printable = no
	veto files = /.snapshot/.windows/.mac/.zfs/
	writeable = yes
	browseable = yes
	access based share enum = no
	vfs objects = zfs_space zfsacl streams_xattr
	hide dot files = yes
	guest ok = no
	nfs4:mode = special
	nfs4:acedup = merge
	nfs4:chown = true
	zfsacl:acesort = dontcare
silverback
silverback
Thanks again.
root:0:root
silverback
silverback
Hmmmm, I must be doing something wrong. When i tried to nano winbindd.core and smbd.core at /var/db/system/cores from an OS X terminal it came up gibberish. Any suggestions?
silverback
silverback
Man this is troublesome. Is it possible my winbndd.core is 140 MB. Both core files were too big to upload. Kind of at a loss here.
