I encountered an error I have been unable to solve today. While troubleshooting a failed flash drive (used for my jails volume), both the 10Gb ports on my board stopped working. When I connect a network cable to either 10Gb port, I receive the following error:
I receive the error on both ix0 & ix1, my 10Gb adaptors.
I have rebooted my server several times, including powering it off and leaving it unplugged for several minutes before restarting. I rebooted my router between one of the server power cycles. I also attempted booting into FreeNAS-11.1-U2 instead of my normal FreeNAS-11.1-U4. In all cases, I received the error shown above when either booting with a network cable connected or upon connecting a network cable to one of the 10Gb ports.
I have searched both these forums and Google for additional troubleshooting ideas and not found anything that I can understand or use. The error is not critical as I am not running a 10Gb network & my 1Gb adaptors are working normally, so I have shifted my network connection to one of those connectors and everything is working fine. However, I would eventually like to run a 10Gb network, it is one of the reasons I purchased my motherboard and I would like to resolve this problem.
Any assistance troubleshooting this problem would be greatly appreciated.
My FreeNAS build specs:
Motherboard: SuperMicro X10SDV-4C+-TLN4F
CPU: Intel Xeon D-1518
RAM: 32GB (2x 16 GB Micron MTA36ASF2G72PZ-2G1A2 DDR4 RDIMM)
Boot Drive: Corsair Force MP500 M.2 2280 120GB PCI-E SSD
Storage Volume Hard Drives: 6x WD Red 4TB (WD40EFRX)
Jails Volume Storage: 2x SanDisk 32GB Ultra Fit (1 currently installed, 1 faulty & removed, replacement on order)
No separate storage or network controllers
FreeNAS Version: 11.1-U4
ix0: Error handling LASI interrupt: -3
