Hi guys,
I've been using FreeNAS on an older PC for a couple of months.
Now I want to build my own production box to store media files and personal data on it.
Currently I'm using 4*4TB WD RED's, but I want it to be expendable to a maximum of 10 disks.
So using 4TB or 6TB disks, it will need around 40GB to 60GB ECC RAM.
It should also be capable to run 3-4 Jails (PLEX, PyLoad, OwnCloud, Syslog/Logstash).
It will also backup my pfSense box and couple of DigitalOcean Droplets through rsync tasks.
There are only a handfull of people accessing it, so it will run most of the time idle.
What I've seen/read, there are 2 possibilites that both support upto 64GB ECC RAM.
The First one is going with an Supermicro X9/X10 board using a LGA2011/LGA2011r3 socket.
The Second would be to use one of the Supermicro's awesome Avoton boards...
I've tested FreeNAS using an i7 860 for the last few months, which is only a bit better then the Atom C2750.
The only CPU intensive task was compilling the PyLoad port... So I don't really see the point in buying a Xeon... HBA and mainboard provide 10 SATA3 and 4 SATA2 Ports which is more then enough...
Build A:
Build A:
- Mainboard: A1SAM-2750F
- RAM: 4 * Intelligent Memory 16 GB ECC
- Power Supply: Seasonic 360W Gold
- HBA: IBM ServeRaid M1015
- Case: Cooler Master Centurion
- HotSwap Bays: 2 * Supermicro CSE-M35T-1 (5 * 3.5" each)
- Mainboard: Supermicro X10SRL-F
- RAM: 4 * 16GB DDR4 RDIMM Samsung M393A2G40DB0-CPB (on the QVL)
- CPU: Intel Xeon E5-1620v3
- Power Supply: Seasonic G-550
