Помогите с логами разобраться
Mihalich
Вроде бы всё работает, но мало ли, в процессе перезагрузки вот такие сообщения:
Mar 15 13:54:00 192.168.21.49 freenas notifier: System shutdown time has arrived^G^G^M
Mar 15 13:54:00 freenas mDNSResponder: mDNSResponder (Engineering Build) (Mar 6 2017 17:10:40) stopping
Mar 15 13:54:00 freenas mDNSResponder: mDNS_FinalExit failed to send goodbye for: 0000000801483580 01 25 _ssh._tcp.local. PTR freenas._ssh._tcp.local.
Mar 15 13:54:00 freenas mDNSResponder: mDNS_FinalExit failed to send goodbye for: 00000008014A4580 01 30 _sftp-ssh._tcp.local. PTR freenas._sftp-ssh._tcp.local.
Mar 15 13:54:00 freenas mDNSResponder: mDNS_FinalExit failed to send goodbye for: 000000080147B580 01 26 _http._tcp.local. PTR freenas._http._tcp.local.
Mar 15 13:54:01 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Mar 15 13:54:01 last message repeated 2 times
Mar 15 13:54:02 freenas ntpd[2581]: ntpd exiting on signal 15 (Terminated)
Mar 15 13:54:03 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Mar 15 13:54:03 last message repeated 2 times
Mar 15 13:54:04 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Mar 15 13:54:04 last message repeated 2 times
Mar 15 13:54:05 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Mar 15 13:54:05 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Connection refused
Mar 15 13:54:05 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Connection refused
Mar 15 13:54:06 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 1
Mar 15 13:54:06 last message repeated 2 times
Mar 15 13:54:07 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 2
Mar 15 13:54:07 last message repeated 2 times
Mar 15 13:54:08 freenas python: dnssd_clientstub ConnectToServer: connect()-> No of tries: 3
Mar 15 13:54:08 last message repeated 2 times
Mar 15 13:54:09 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:7 Err:-1 Errno:61 Connection refused
Mar 15 13:54:09 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:6 Err:-1 Errno:61 Input/output error
Mar 15 13:54:09 freenas python: dnssd_clientstub ConnectToServer: connect() failed path:/var/run/mdnsd Socket:4 Err:-1 Errno:61 Input/output error
Mar 15 13:56:17 freenas root: /etc/rc: WARNING: failed precmd routine for vmware_guestd
Mar 15 13:56:23 freenas mDNSResponder: mDNSResponder (Engineering Build) (Mar 6 2017 17:10:40) starting
Mar 15 13:56:23 freenas mDNSResponder: mDNS_AddDNSServer: Lock not held! mDNS_busy (0) mDNS_reentrancy (0)
Mar 15 13:56:23 freenas mDNSResponder: CheckNATMappings: Failed to allocate port 5350 UDP multicast socket for PCP & NAT-PMP announcements
Запущены три службы: SMART, SMB, SSH. NAS введён в Домен
