vaderaardbei
- May 31, 2022
I'm running TrueNAS-SCALE-22.02.1
I've had some power outages and 2 pools fail to import at boot. However running zpool import <ID> does import them flawlessly.
zpool status does not list the pools ony the available ones:
zpool import
pool: pool
state: ONLINE
After importing the pools are listed without any errors. they are also online in the GUI:
root@truenas[/sbin]#
The boot pool import process also keeps running. And it seems that that is a middleware process which does not have the right references to the pools. How can i fix this? my apps are on vpool and they fail to run unless i start restart app container processes manually? But ive never tried that.
./zpool status
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:33 with 0 errors on Wed May 25 03:45:34 2022
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
sda3 ONLINE 0 0 0
errors: No known data errors
pool: pool
state: ONLINE
scan: scrub repaired 0B in 06:08:15 with 0 errors on Sun May 22 06:08:22 2022
pool ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
ba0faddd-3f8d-4fd9-86cc-017af653a6bd ONLINE 0 0 0
5cb3b860-a2c2-41ff-a886-e11102fb2b0d ONLINE 0 0 0
7e40aba3-92ed-4222-aa8b-8df5f6919ad5 ONLINE 0 0 0
logs
23519f0b-f608-46f7-ad5b-b4d9a374f882 ONLINE 0 0 0zpool import
root@truenas[/sbin]# ./zpool import
pool: vpool
state: ONLINE
action: The pool can be imported using its name or numeric identifier.
vpool ONLINE
b32e3682-432f-42d4-a5e4-2130d3d7c3ab ONLINE
pool: vpool2
state: ONLINE
vpool2 ONLINE
1f6b39fb-8a2b-41df-854b-d6f7385b8ff2 ONLINE
root@truenas[/sbin]# ./zpool import 7567855823430550315
root@truenas[/sbin]# ./zpool import 14650810130880312133
pool: pool
state: ONLINE
./zpool status
pool: boot-pool
state: ONLINE
sda3 ONLINE 0 0 0
pool: pool
state: ONLINE
pool ONLINE 0 0 0
logs
pool: vpool
state: ONLINE
vpool ONLINE 0 0 0
b32e3682-432f-42d4-a5e4-2130d3d7c3ab ONLINE 0 0 0
pool: vpool2
state: ONLINE
vpool2 ONLINE 0 0 0
1f6b39fb-8a2b-41df-854b-d6f7385b8ff2 ONLINE 0 0 0
root@truenas[/sbin]#The boot pool import process also keeps running. And it seems that that is a middleware process which does not have the right references to the pools. How can i fix this? my apps are on vpool and they fail to run unless i start restart app container processes manually? But ive never tried that.
