removing non existent pool - specific truenas scale
nbhanji
when I perform zpool status -v
root@truenas[~]# zpool status -v
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:19 with 0 errors on Fri Feb 4 03:45:21 2022
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
sda3 ONLINE 0 0 0
errors: No known data errors
pool: data-pool-02
state: ONLINE
data-pool-02 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
570c7afe-0a21-40a5-8f24-e2f945ad4412 ONLINE 0 0 0
0248fc6e-f9b9-4049-8f18-13ab1ff64ce8 ONLINE 0 0 0
Under GUI, this is what shows:
when i select/click on export/disconnect:
when I select export/disconnect:
Not sure if this is a bug or there is a way to resolve. I have searched forums and web, nothing that can solve for me. Any help is appreciated.
Thanks.
Danpomeroy
Any luck with this?
pool: boot-pool
state: ONLINE
sda3 ONLINE 0 0 0
pool: data-pool-02
state: ONLINE
Thanks.
Any luck on this?
nbhanji
Unfortunately no, for now I just ignore it. I know it does not exist and therefore, not use it or look at it. :)
Danpomeroy
ugh... ok. If I stumble on anything I will let you know. Thank you!
You could look at this one... (works for both SCALE and CORE)
Danpomeroy
Problem is my 'zombie' pool is the same size as the real pool. Can't create that file to be the same size if there isn't room.
Doesn't matter if it's different, but also doesn't take the space as it's a sparsefile... only would grow to that size if you wrote data to the pool before removing it.
Danpomeroy
Ahh, thank you for that. I didn't realize.
I will give it a try later.
Danpomeroy
I was able to remote in and follow this. It worked perfectly, and quick!
Thank you!!
