Zpool unavailable after hardware upgrade
Gooberpatrol66
I had a freenas server running 2 mirrored 1tb hard drives in one zpool. I moved to a new motherboard and added 2 more hard drives and the volume disappeared, even though all 4 hard drives are online. How can I get it back?
zpool import -c /boot/zfs/zpool.cache.bak
   pool: Vol1
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://illumos.org/msg/ZFS-8000-3C
        Vol1                     UNAVAIL  insufficient replicas
          mirror-0               UNAVAIL  insufficient replicas
            9085847569967387614  UNAVAIL  cannot open
            8792823045204158374  UNAVAIL  cannot open
zpool import -d /dev does nothing.
Arwen
Try running a simple;
zpool import -o mountpount=/mnt/Vol1 Vol1
My take is that the new hardware uses a different drive naming convention than
your old hardware. Thus, the ZFS cache file can't pick up the disks. Let ZFS find
the disks for you.
depasseg
FreeNAS Replicant
Have you tried to use the GUI to import the pool? If you use the cli, freenas won't be aware of it.
Gooberpatrol66
the disks for you.
I get property 'mountpoint' is not a valid pool property
The pool does not appear in the GUI.
depasseg
FreeNAS Replicant
Arwen
Sorry, it's really;
zpool import -R /mnt/Vol1 Vol1
Sometimes it's hard to get the exact syntax of a command, if you can't try it out.
Gooberpatrol66
Can you provide a screenshot of what FreeNas presents at Step 2 of the "Import Volume" process?
http://doc.freenas.org/9.10/storage.html?#import-volume
Sorry, it's really;
cannot import 'Vol1': no such pool available
depasseg
FreeNAS Replicant
And what is the output of 'camcontrol devlist -v'?
SweetAndLow
Sweet'NASty
output of glabel list and gpart show?
Gooberpatrol66
scbus0 on ahcich0 bus 0:
<>                                 at scbus0 target -1 lun -1 ()
scbus1 on ahcich1 bus 0:
<>                                 at scbus1 target -1 lun -1 ()
scbus2 on ahcich2 bus 0:
<>                                 at scbus2 target -1 lun -1 ()
scbus3 on ahcich3 bus 0:
<>                                 at scbus3 target -1 lun -1 ()
scbus4 on ahcich4 bus 0:
<>                                 at scbus4 target -1 lun -1 ()
scbus5 on ahcich5 bus 0:
<>                                 at scbus5 target -1 lun -1 ()
scbus6 on ahcich6 bus 0:
<>                                 at scbus6 target -1 lun -1 ()
scbus7 on ahcich7 bus 0:
<>                                 at scbus7 target -1 lun -1 ()
scbus8 on ahcich8 bus 0:
<Corsair Force GT 5.07>            at scbus8 target 0 lun 0 (ada0,pass0)
<>                                 at scbus8 target -1 lun -1 ()
scbus9 on ahcich9 bus 0:
<>                                 at scbus9 target -1 lun -1 ()
scbus10 on camsim0 bus 0:
<>                                 at scbus10 target -1 lun -1 ()
scbus11 on umass-sim0 bus 0:
<Sony Card R/W  -CF 1.40>          at scbus11 target 0 lun 0 (pass1,da0)
<Sony Card R/W  -SM/xD 1.40>       at scbus11 target 0 lun 1 (pass2,da1)
<Sony Card R/W  -SD 1.40>          at scbus11 target 0 lun 2 (pass3,da2)
<Sony Card R/W  -MS 1.40>          at scbus11 target 0 lun 3 (pass4,da3)
scbus-1 on xpt0 bus 0:
<>                                 at scbus-1 target -1 lun -1 (xpt0)
[root@freenas ~]# glabel list
Geom name: ada0p1
Providers:
1. Name: gptid/e7a37ee2-9b0e-11e4-a4e8-94de80a88096
   Mediasize: 524288 (512k)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
   secoffset: 0
   offset: 0
   seclength: 1024
   length: 524288
   index: 0
Consumers:
1. Name: ada0p1
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r0w0e0
Geom name: ada0p2
Providers:
1. Name: gptid/e7a41ad8-9b0e-11e4-a4e8-94de80a88096
   Mediasize: 60021915648 (55G)
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e1
   secoffset: 0
   offset: 0
   seclength: 117230304
   length: 60021915648
   index: 0
Consumers:
1. Name: ada0p2
   Sectorsize: 512
   Stripesize: 4096
   Stripeoffset: 0
   Mode: r1w1e2
[root@freenas ~]# gpart show
=>       34  117231341  ada0  GPT  (55G)
         34          6        - free -  (3.0k)
         40       1024     1  bios-boot  (512k)
       1064  117230304     2  freebsd-zfs  (55G)
  117231368          7        - free -  (3.5k)
SweetAndLow
Sweet'NASty
Looks like your disks aren't connected. Check your cables and controller.
depasseg
FreeNAS Replicant
What are the system specs? What is the "Sony card"?
Sent from my Nexus 9 using Tapatalk
Full hardware listing, please. Before and after. It should've been included right at the start. You can't expect people to guess what you've been doing.
Gooberpatrol66
weird, because I see 4 disks under "view disks". I just noticed they all have size of 0, though. Maybe my drive cages are bad?
Just an SD card reader I threw in there because I had nowhere else to put it
Define "full". I have an SSD with freenas on it and 2 1TB hard drives I moved over from a gigabyte z87n motherboard to a supermicro x10srl-f motherboard, and then added 2 blank 1TB drives.
My guess is that they're just the card reader. It shows up as four separate SCSI devices.
Very important detail there. Get rid of everything between the SATA controller and the drives, except for short-ish SATA cables (0.5m maximum). Touch the drives to make sure they've spun up, too.
depasseg
FreeNAS Replicant
Doubtful that those 4 disks are what you were expecting, since camcontrol and glabel both show exactly one physical hard disk connected, and that is your SSD boot disk.
