hi. im using raidz2 with 4 pcs 2TB - unfortunately two of the harddrive failed and resulted to geometry error.
i tried to replace the hard disk on the zpool and afterwards i encountered a zpool error and unknown status.
using the zpool import. i have these result.
[root@freenas ~]# zpool import
pool: storage
state: FAULTED
status: The pool metadata is corrupted.
action: The pool cannot be imported due to damaged devices or data.
The pool may be active on another system, but can be imported using
the '-f' flag.
see: http://www.sun.com/msg/ZFS-8000-72
storage FAULTED corrupted data
raidz2-0 DEGRADED
ada0p2 ONLINE
replacing-1 UNAVAIL insufficient replicas
6165662555358837975 UNAVAIL cannot open
176234172407761611 UNAVAIL cannot open
replacing-2 UNAVAIL insufficient replicas
18202566125230260674 UNAVAIL cannot open
15749487608898309886 UNAVAIL cannot open
ada1p2 ONLINE
is there a way to fix this and recover the data?
pool: storage
state: FAULTED
the '-f' flag.
raidz2-0 DEGRADED
ada0p2 ONLINE
ada1p2 ONLINE
