TheAbyssDragon
- Apr 30, 2015
I have a 7 disk raidz2 built from a mix of 2.0 TB WD Blacks and Seagate Barracudas on FreeNAS-9.3-STABLE-201502162250. Unfortunately the system is all consumer grade, but I do have proper backups in case of catastrophic failure.
On Monday I had a double drive failure (one drive failure probably happened last week and went unnoticed) and a third drive throwing errors. Somehow this caused an error in the web gui saying that the size of the zpool could not be determined, so I detached the volume and proceeded to the command line.
I've since imported the zpool, replaced both faulty disks, and am in the process of scrubbing the pool now. See my "zpool status -v" below. The disk with cksum errors is the third disk that is going bad, I should have a replacement for it soon.
I can mount/unmount the various datasets and interact with all of the files. However, the zpool doesn't show in the web gui under storage. Instead I get "No entry has been found". If I try to auto-import, the drop down is blank; I'm guessing this is because the volume has already been imported.
How do I get my zpool to show in the web gui again?
pool: zpool1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: scrub in progress since Thu Apr 30 09:29:29 2015
576G scanned out of 6.96T at 257M/s, 7h14m to go
0 repaired, 8.09% done
NAME STATE READ WRITE CKSUM
zpool1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/82898f22-c26e-11e4-ab59-fcaa1484a02d ONLINE 0 0 0
gptid/b4246a42-d05f-4811-9714-6f91f84f62fb ONLINE 0 0 0
gptid/35cc7cb5-18f4-11e4-a47e-1c6f655a6c78 ONLINE 0 0 267
gptid/79f68319-7194-11e4-a5ec-1c6f655a6c78 ONLINE 0 0 0
gptid/2c083ccc-6aa7-11e4-a073-1c6f655a6c78 ONLINE 0 0 0
gptid/36c7b08d-18f4-11e4-a47e-1c6f655a6c78 ONLINE 0 0 0
gptid/3724190c-18f4-11e4-a47e-1c6f655a6c78 ONLINE 0 0 0
errors: No known data errors
