As the title says, I'm having a bit of an issue after the installation when importing the ZFS volumes. after scouring through the forum threads for hours trying to find answers, I have came to some conclusion but also technical hurdle which I cannot figure out how to get over.
I have this one particularly overfilled volume prior to the replacement/upgrade of FreeNAS and now have trouble importing via GUI, the GUI sees the volume and always end up with errors and asked to check the pool status.
So I opened up the shell and do a zpool status and got the below output (truncated):
so I exported the pool in CLI and attempted a manual mount with
and got the following result:
using:
returns (truncated):
I read people have success deleting/nulling non-important files in the pool before they are able to Auto Import the volume via GUI again in several threads, however, my question is, all my files are in the 2 dataset mountpoints that failed to mount and I don't quite know how to access them so that I can delete the files.
The other potential option is to add extra disk/vdev to the pool which might solve the problem, however what do I need for that to happen, this is a 8x2TB RAIDZ2 array, and I don't quite know how to achieve it with the GUI even assuming if I have the hardware resources to do it as the volume won't show up in the Volume Manager.
Any help would be appreciated!
moppidoo
pool: WiredSTO_02
state: ONLINE
  scan: scrub repaired 0 in 10h50m with 0 errors on Sat Jan 10 16:20:32 2015
        WiredSTO_02                                     ONLINE       0     0     0
          raidz2-0                                      ONLINE       0     0     0
            gptid/f24bc20e-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f2bfda19-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f33d08f8-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f3beaa89-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f46a91fd-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f5067074-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f59ddfa2-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
            gptid/f6094fa9-441e-11e2-9642-bc5ff448f101  ONLINE       0     0     0
errors: No known data errorsso I exported the pool in CLI and attempted a manual mount with
zpool import -R /mnt WiredSTO_02
cannot mount '/mnt/WiredSTO_02/MMWPublic_02': failed to create mountpoint cannot mount '/mnt/WiredSTO_02/P_Kollectionz': failed to create mountpoint
using:
zfs list
NAME USED AVAIL REFER MOUNTPOINT WiredSTO_02 10.1T 0 427K /mnt/WiredSTO_02 WiredSTO_02/MMWPublic_02 4.04T 0 4.04T /mnt/WiredSTO_02/MMWPublic_02 WiredSTO_02/P_Kollectionz 6.08T 0 6.08T /mnt/WiredSTO_02/P_Kollectionz
moppidoo
