After almost a year of lurking, reading a lot, researching and finally building my own FreeNAS server, I'm encountering my first problem I can't seem to solve on my own :)
Just some background: I built a FreeNAS based on a Xeon E3-1230v5, Supermicro X11SSL-CF, supported Samsung ECC RAM (32GB) and 2 pools: a mirrored SSD pool for my test VMs (2x250GB) and a raid-z2 pool for my data (6x4TB WD Reds). One quirk: I'm running FreeNAS as a VM on ESXi, with all my disks passed through and all configuration done as described in these forums and the 'official' blog post by the FreeNAS project. The build was done in July this year, so not too long ago.
Today I got some worrisome mails from my FreeNAS telling me one of the WD Reds was unavailable and the data zpool was degraded. And indeed:
(Don't mind the root thing, my infra is still being built appropriately :p)
Apparently, SMART also started failing for this disk:
But the weird thing is, smartctl output doesn't show anything:
I checked all other disks to make sure they were not renumbered, but this one is clearly The One (serial matches with GUI output for /dev/da3). All other disks have the same SMART output and no disk is missing. smartctl -x also shows recent readouts successfully done:
Trying to bring it back online clearly fails though:
I'm a bit confused here. I fully accept something is wrong with the disk and I should replace it (replacement disk is already on its way, should have provided a spare disk at the start), but how can I verify what is going wrong with this disk if smartctl isn't showing anything (although the errors are clear in the log)?
My current guess is: the disk is b0rked, SMART failed a couple of times so FreeNAS is 'blocking' it, and it's only a matter of time before it completely dies on me. Possible?
Thanks!
Edit: just noticed the g_eli_read_done errors rereading my post, but to be clear: I have no encryption enabled on any zpool.
[root@duvel] ~# zpool status zpool-data -v
cannot open '-v': name must begin with a letter
pool: zpool-data
state: DEGRADED
status: One or more devices could not be opened. Sufficient replicas exist for
the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
see: http://illumos.org/msg/ZFS-8000-2Q
scan: scrub repaired 0 in 0h51m with 0 errors on Thu Sep 15 02:51:41 2016
NAME STATE READ WRITE CKSUM
zpool-data DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/c3c0ff42-4ac9-11e6-9a8e-0cc47a81f344 ONLINE 0 0 0
gptid/c4e14e68-4ac9-11e6-9a8e-0cc47a81f344 ONLINE 0 0 0
6054603385877469052 UNAVAIL 3 152 0 was /dev/gptid/c5fc4597-4ac9-11e6-9a8e-0cc47a81f344
gptid/c71aad36-4ac9-11e6-9a8e-0cc47a81f344 ONLINE 0 0 0
gptid/c83372aa-4ac9-11e6-9a8e-0cc47a81f344 ONLINE 0 0 0
gptid/c9514fab-4ac9-11e6-9a8e-0cc47a81f344 ONLINE 0 0 0
errors: No known data errors
[root@duvel] ~# date Mon Sep 26 17:49:28 CEST 2016 [root@duvel] ~# tail -20 /var/log/messages Sep 26 07:43:49 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d5 00 01 00 01 00 4f 00 c2 00 b0 00 length 512 SMID 232 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:49 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 06 2c 00 da 00 00 00 00 00 4f 00 c2 00 b0 00 length 0 SMID 769 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:50 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 06 2c 00 da 00 00 00 00 00 4f 00 c2 00 b0 00 length 0 SMID 223 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:50 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 338 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:50 duvel smartd[3455]: Device: /dev/da3 [SAT], failed to read SMART Attribute Data Sep 26 07:43:50 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d0 00 01 00 00 00 4f 00 c2 00 b0 00 length 512 SMID 638 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:50 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 895 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:51 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d5 00 01 00 06 00 4f 00 c2 00 b0 00 length 512 SMID 373 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:51 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d5 00 01 00 01 00 4f 00 c2 00 b0 00 length 512 SMID 153 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 07:43:51 duvel (pass4:mpr0:0:2:0): ATA COMMAND PASS THROUGH(16). CDB: 85 08 0e 00 d5 00 01 00 01 00 4f 00 c2 00 b0 00 length 512 SMID 372 terminated ioc 804b scsi 0 state c xfer 0 Sep 26 08:00:50 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=0, length=131072)] Sep 26 08:00:50 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=262144, length=131072)] Sep 26 08:00:50 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=2146959360, length=131072)] Sep 26 08:00:50 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=2147221504, length=131072)] Sep 26 12:44:00 duvel upsd[2571]: Data for UPS [ups] is stale - check driver Sep 26 12:44:00 duvel upsd[2571]: UPS [ups] data is no longer stale Sep 26 17:11:51 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=0, length=131072)] Sep 26 17:11:51 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=262144, length=131072)] Sep 26 17:11:51 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=2146959360, length=131072)] Sep 26 17:11:51 duvel GEOM_ELI: g_eli_read_done() failed (error=6) da3p1.eli[READ(offset=2147221504, length=131072)]
[root@duvel] ~# smartctl -a /dev/da3
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40EFRX-68WT0N0
Serial Number: WD-WCC4E5NZXNCS
LU WWN Device Id: 5 0014ee 262b146ed
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Sep 26 17:50:04 2016 CEST
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (52980) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 530) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 206 179 021 Pre-fail Always - 6675
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 1779
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 11
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 0
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 773
194 Temperature_Celsius 0x0022 119 111 000 Old_age Always - 33
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 1689 -
# 2 Short offline Completed without error 00% 1641 -
# 3 Short offline Completed without error 00% 1593 -
# 4 Extended offline Completed without error 00% 1558 -
# 5 Short offline Completed without error 00% 1545 -
# 6 Short offline Completed without error 00% 1497 -
# 7 Short offline Completed without error 00% 1449 -
# 8 Short offline Completed without error 00% 1401 -
# 9 Short offline Completed without error 00% 1353 -
#10 Short offline Completed without error 00% 1305 -
#11 Short offline Completed without error 00% 1258 -
#12 Extended offline Completed without error 00% 1222 -
#13 Short offline Completed without error 00% 1210 -
#14 Short offline Completed without error 00% 1162 -
#15 Short offline Completed without error 00% 1138 -
#16 Short offline Completed without error 00% 1090 -
#17 Short offline Completed without error 00% 1042 -
#18 Short offline Completed without error 00% 994 -
#19 Short offline Completed without error 00% 946 -
#20 Short offline Completed without error 00% 898 -
#21 Short offline Completed without error 00% 850 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Index Estimated Time Temperature Celsius 477 2016-09-26 09:54 33 ************** ... ..(476 skipped). .. ************** 476 2016-09-26 17:51 33 **************
[root@duvel] ~# zpool online zpool-data 6054603385877469052 warning: device '6054603385877469052' onlined, but remains in faulted state use 'zpool replace' to replace devices that are no longer present
Thanks!
