ZIL removed how to restore Pool?
velocity08
Hi All
have been looking for some clear information on how to restore a pool when a ZIL is removed or a single drive Zil dies.
Have seen different comments around but nothing 100% solid.
did a quick experiment on FreeNas and removed the ZIL and the pool was showing as offline.
Couldn't find a straight forward answer on how to detach the ZIL from the pool and import back.
Would love to learn both UI and terminal methods.
""Cheers
G
Remove ZIL/SLOG
zpool remove <poolname> <disk> (gptid or /dev format)
Add ZIL/SLOG
zpool add log <poolname> <disk> (gptid or /dev format)
HoneyBadger
actually does care
Administrator
Removing the SLOG device from an imported pool is easy enough as indicated by @sretalla and should even work to remove a dead/missing device.
If the SLOG dies on a reboot after powerloss though, you need to use zpool import -m from a shell, and you will lose any pending data that wasn't written to the pool. (This is why mirrored SLOG is recommended for "every single bit matters" workloads.)
As far as there being a GUI method to do it, I'm unsure. Something on my to-do list to check out, I guess?
velocity08
Awesome thank you both exactly what i was looking for,
Yes agreed and understand in a mirror for production :)
was just working through testing some scenarios and wanted to verify we had the correct information before doing more testing.
If you find a way in the GUI in your travels please post if you can.
thanks again.
""Cheers
G
